I found a kit on
ebay that does both sides and it is $100. Is this the right kit for me?
Basic Front End Seal kit
Suits all 80 series and live axle 100 series.
Do you have wet leaking swivel housings. Guess what - they're not supposed to have oil in them so where is it coming from? I bet your axle seal is shot and the diff oil has washed the grease out of your CVs and wheel bearings. Not Good! It gets worse, that oil leaks all over your brakes and the missus spots the oil on the drive...
This kit includes axle seal (Toyota want $15+ for this same part alone), hub seal and all gaskets to do one front wheel. If you have just one leaking seal then this kit is a budget solution. Of course you can buy 2 (upon winning) and do both sides.
We also sell a complete kit that does both sides and that kit includes swivel bearings and seats as well as swivel felts. Refer to
ebay item 190105778619 ($99.95) in my
ebay store.
However, there are those (and I am one) who like doing the full monty and go all new stuff through out. It's your call - I am here to serve you. You have the following optional upgrades - CV joints for 80/some 100 series $65 ea, Hub socket $30, Hub Nut Kit $10 per side, wheel bearings $25 per side.
Here's a tip for the DIY mechanic at home (no torque wrench or figures) - don't over tighten your wheel bearings. This causes over heating, the grease thins down like water and runs out of the bearing and it will then seize - not good! Do the job with the wheel fitted but jacked off the ground and no weight on it. Tighten the bearings enough so that you just eliminate the side play. It would pay to check them again once they have worn in - say in a few hundred k's.
If you run large tyres (greater than 33") randomly jack up the front wheels and check for play as large tyres place a great deal of stress on bearings.
