Sway bar bushing kit for wagons
Chattanooga, TN
Thought I'd post up some things I found to be pretty cheap and good quality. Not sure if the 40s have the same setup but OReilly's Auto has a front swaybar bushing kit pretty cheap and good quality IMO. Got these for $6.99/ea which included a Grade5 bolt, collar, washers, lock nut and rubber bushings. The MOOG brand was $1 more.
Part Number is K5254 $6.99/ea.
Sean,
What is the length of the bolt? My BJ70s would use the same hardware as your 60. Thanks
Sean,
The bolt measures 8" from under hex head to end of threads. I have 1.5" extended shackles with flat saggy springs so you are probably looking at 3/4"~1" of lift only on the front.
