Swapping thirds, front to rear???
Kansastitty
When I put a 12/76 front axle under my '65 FJ40, I saved the third member out of theold housing under the assumption that I could replace the one in the rear axle that has some slop in it. Am I nucking futs, or do they interchange? My old axle had lockouts, so I figure it has less wear than the rear, anyway it seems pretty tight, tighter than the current one, anyway.
So, can you swap a front third for a rear pretty easily???
Thanks,
Ed
Thanks! Glad I saved it!
Ed
Anyone have a pre-67 unworn front third laying around? :frown: :) ;)
Just make sure when you put the front third in the rear that you also install the thrust block assuming that you have a semi-floater axle. If not you'll loose your axles in short order.
What is the "thrust block" and where does it go? I assume I can reuse the one that's in there?
Thanks for the heads-up!
Ed
Thanks, Pablo!
Ed
Thrust block = "Differential pinion spacer" in the FSM. It keeps the rear axle retainer c-clips in place. I did this swap on my 66 and it's easy. While you've got it torn down, it's a good time to pop in fine spline side gears and axles, if you've ever considered it. You'll have it all apart anyway. Have fun!
I notice from the FSM there are 3 different sizes. You have to check the clearance and make sure you have the correct size.
It's not a direct swap.. as you have to swap out side gears. The 65 have course vs latter fine... Everything can be made to work but it's not a drop in right...
Well, it's nearly drop in. To pull the rear third, you'll need to pull the carrier pin to get the spacer out, then the rear axle retainer c-clips. The side gears can be removed at this point really easily. You'll need to pull the pin on the front diff too, to put the spacer in when you put in the back. I'm not sure about how much of a pain it is to do it while in truck - I pulled my whole rear axle housing when I did mine, so was able to angle things like I needed on reassembly. There's kind of a trick to inserting the side gears and spiders, meshing it all, catching the spacer and having it all mesh, and it feels pretty cool when you get it figured out and it just rolls into place. Take it slow and thoughtful - it's not something I'd recommend after a fight with the SO. Need kind of a zen state.
There are three thicknesses of spacer, but see if you can ask around to get the ones you don't have - they're pretty common in people's boxes of stuff, they get taken out when lockers go in, I believe. Last years swap meet a guy sold a big box of assorted side gears, spacers and pins for $5.00, so they're not a high demand collectable. I would think that the most critical thing is you don't want it too tight - but I'm not a 3rd member specialist.
One thing you really need to be careful of is the torqe on the locking pin. Breaking that can bring a world of grief, and it's not a very big beefy bolt. I reused mine, because the third member looked pretty unmolested, but if yours has been gotten into much, it may have been overtorqued, and it might be wise to spend the $5 on a new locking pin. It seems like it was only torqued to 25 ft/lbs or so, but double check that.
If you don't go with the fine side gears, you can just insert your axles, pull the pin, then use a magnet to drop the spacer in slow while you reinsert the pin - i used one of my magnetic holders for welding and it worked great. Then check for clearance - FSM says 0.0024 - 0.019". The available spacers are
1.172 - 1.173"
1.188 - 1.189"
1.204 - 1.205"
Good luck.
I would like to reiterate what jim said. I deal with it every day ( with Fords). I would go and buy a couple of the lock pins and ALWAYS replace them. I have only reused them when I wasn't putting the third back in a truck. It's not worth risking it.
But I would be swapping the front third out of my '66 axle into the rear of the same '66, so no need to change side gears? Still coarse axles in the rear.
Thanks all for the info.
Ed
Ed,
You can re-use your side gears and axles.
People were just saying this would be the time to upgrade to fine spline, if you had or could find fine spline axles and side gears...
Cheap labor, as you will already be in there!
BTW, this is a good time to replace your axle seals on the rear if you have not done so for a while. Just slide the axles all the way out, and be careful when you slide them back in.
oh.. I didn't read it clearly. :doh: you have the fine spline 78 axle up front and saved the coarse front. Now you want to put the coase front in the rear. It'll drop right in. I'd see if you could find a fine spline rear just drop that in with a new used diff. :cheers:
