swaping front axle on a fj40 75 drum brakes for an fj60 disk brakes, has anyboady done it??
what should I whach out for???
How about on a 69, I'll be doing the axle swap and a brake booster upgrade on that 69...
cheers
you have to outboard your springs to make it work, or notch the housing. Give a shout if you need pics.
If you just want the brakes it will be much easier to swap over the stuff onto your housing. Just remeber to re shim your knuckle to the correct preload.
69 is a PITA just ask me how a know You have to replumb the entire vehicle with and cut and move the body ribbing.
here you go this is what is involved plus a little
bustanutley
for the 69 I'll be doing the axle swap + booster brake + propo valve + whatever brake lines and tubing I can get. show me more pictures of the axle swap if you can. you're concentrating more on the SOA than what my friend actually wants... on my 76 i think I'll do the knuckle replacement, I rebuilt my axle not long ago...
when I get home I'll take some pics and post them up if the freaking Internet is working.
What parts are you curious about? Mostly brake stuff? It’s not too bad. I got pissed and just cut the body ribbing out to get the booster in there. I'm using the stock clutch master that is pressed against the brake booster but one out of an fj60 would be better because they are significantly smaller, but you would have to rework the hydraulics a little. The brake lines I used for the firewall are out of a Toyota mini truck but I’m pretty sure newer 4 runners and pickups are pretty much identical from what I was in the yard. I definitely recommend grabbing prebent lines just makes life easy. After that you just have to tweak a few pieces of brake line to get them to where they are going. Let me know what you would like to see or hear.
Oh and i'm using a mini truck booster and master as well, no porportioning valve, stops great.
