Suspension rattling?
Athens, GA
I have a weird rattle that started to happen whenever I am at low speeds and go over a bump. It seems to happen more when I am turning, the suspension or axle or something makes a clunk type sound. When I am driving down the road, everything is normal, and when I hit speedbumps or any bumps from head on, the noise seems to rarely happen. 4WD engages and everything seems tight underneath. Any ideas?
Torque check all your control arm control arm connections. These large bolts require a great deal of torque.
Shock mount or sway bar mount giving out? The rubber sections deteriorate and things will bang around if that happens.
Sway bar bushings
^^^^This
When those sway bar bushings wear out, they cause a whole lot of noise, especially on bumpy roads at slow speeds!
