sleeoffroad said:It is a little difficult to explain everything here since there we discussed the pro's and the cons over the phone.
Fitting the 863 is not the solutions. The 866 is the right spring for this application. Mike was aware and knows how to retain the springs. If need be, it needs to be done top and bottom.
863's will yield about 4" of lift in the rear and the front can not be set up to match. So he will have a rake of about 2". That is not going to work. Plus the ride won't be nice.
The bumper issue was also discussed at that time it was not in the cards.
"Dealing with the unseated springs" is meant to be make sure they don't. Not go on the trail and figure out what to do when they fall out![]()
No bumper. Hmm. Well, then I guess he probably will have to retain that spring from the top also. If he does that he's set.
4" lift with an 863 on a 100? How come you don't get 4" on an 80 with an 863? I'm at 4" on my 80 and have 20mm atop the spring.
