So, question. Everyone talks about shocks and springs and radius arms and drop brackets (and drop boxes) and caster plates and washer mods and so on and so forth, and that's all good info. But where's the love for everything else? It seems a little like those guys who blast their upper bodies at the gym, and look awesome--but it's all carried on these little toothpick legs. You duck the haymaker, sweep a leg and they're done. Obviously an imperfect analogy; 80 stock parts are hardly toothpicks. But still; you change or beef one thing, and others are affected--sometimes catastrophically.
Yes, there's a ton of very detailed information on specs in the compiled suspension spec thread, here:
forum.ih8mud.com
But that seems largely for the advanced practitioner, so to speak. A title search of this forum shows zero hits on "suspension primer" or "suspension basics." It seems to me that something like that would be useful to those who--like me--have never touched a suspension component. (You remember those days, right?)
So how about some really ground-level information to give those new to this a basic understanding of what happens when you lift the vehicle, the various options for addressing alterations to the stock geometry--and just what the heck is meant by Stage 1, 2, 3, 4, etc.
For example, I'm running on a stock-height OME suspension installed by the PO in 2011, and four blown-out OME shocks (also courtesy the PO). 33" tires and no desire to ever go above 35." I'm about to put in a new suspension with a modest lift, "estimated" at 2 inches. This to handle extra weight more than anything else. Front coils for 110-240 lbs over stock, rear 220-660 over stock. According to the lift kit maker, that means...
So what's the deal here? Do these *** things actually need to be modified, or not? The very fact that there's a kit without them implies they may be optional. (Or perhaps people just plan to pick those parts up somewhere else?) For that matter, do you really need the steering damper?
If they are optional, at what lift height to they become mandatory? How high do you have to be before you need extended brake lines, or a lowered LSPV bracket? Or who-knows-what-else? Does lift affect camber as well as caster? And what's all this about disconnecting sway bars (also called anti-sway bars; how's that for clarity)? What's the problem with 3-links? When do you need double cardan driveshafts? Do you need longer driveshafts? Shorter? Which suspension mods can be dangerous, and under what conditions?
You can see how this might confuse a newcomer. Leave them in suspense, even.
So, for the uninitiated--what do all these things do, and what conditions are they meant to correct or improve? Sure, newbies could go threadhopping for a week (or a year) to find out--but why not put that info here, or link it from here, to make it easy? Also, maybe an at-a-glance checklist to kick things off. What should be looking at doing for a 2" lift? 3" 4" 5" 6" or giraffe-height lift? My limited understanding is that the higher you go, the more unstable and out of whack things get, with cost and complexity hurtling skyward like Apollo. (Or maybe Jeff's c*ck rocket; you get the idea.)
Compiled 80 series suspension component spec thread... shocks, coils & more.
80 series coil & shock specs A few years back 80 series suspension was fairly easy to figure out & purchase since there was only a few of options to chose from. Recently there has been a few suppliers stepping up to play in the USA 80 series market offering more options. Now with a plethora of...
forum.ih8mud.com
- Front Coil Springs
- Rear Coil Springs
- Front Shocks
- Rear Shocks
- Rubber 2° Caster Bushing Kit
- Steering Damper
- Upper Trailing Arms ***
- Lower Trailing Arms ***
- Front Panhard Bar ***
- Rear Panhard Bar ***
- Adjustable Drag Link ***
