Suspension and doubts
La Paz Baja California Sur (Mexico)
Well... now I have my FZJ in Baja California, tree mounth of researc and test, but now I have...
I am very a happy but now is the moment of the doubts... which suspension?
My european and African expirience with my KDZ95 no has doubts...KONI RAID but in US ...is strange I can't find it and importo to Europe not is very easy....
Well....my tipycal driving is in Baja Sur....sand and rocks ( no crawling)....
OME? Blisten? Fox ? other ? i do not know this and I have a Koni Raid Budget for 4 suspension ...1.000 USD...
I would like have some suggestion about my choose... Thanks a lot and sorry for my strange english....
62 views and no comments so far... I thought you would at least get, "Use the search function!"
I suppose the answer is that you need to decide for yourself. Most likely you'll change your mind, and wish you had done something else. The good news is that whatever you do choose, you should be able to sell the used parts to someone else who wants to do whatever you started with.
I started thinking this: https://forum.ih8mud.com/threads/spring-spacers-and-stock-springs.818286/
With stock aging springs and no spacers (and your current shocks) you should be able to fit tires up to 33". Cost $0
With a small lift, you can still keep your shocks, still only plan to fit tires up to 33"; but it will look better (to me, you might prefer the stock look.)
With a big lift you can fit 35" or 37" tires, but you'll blow your $1000 budget with new shocks and most likely a double carden front drive shaft.
If you really need advice, I advise you to keep it stock for a while. Drive it on the trails you enjoy. See what YOU want to change.
Although I really did plan to just add spacers on top of the springs, my plan changed before I bought spacers. My current plan (and I have the parts, and just need to put them on the Cruiser) is OME medium from springs. OME heavy rear springs, and ICON stage 1 shocks. A pair of springs (front or rear) run about $150 - $170 ($US) on Amazon. I got my ICON shocks on MetalTech's Black Friday sale, but there are lots of shocks. Many are $50 - $150 each. I bought a Monroe steering stabilizer on Amazon for around $28. Castor correction will cost what it does. Plates or OME bushings will run $80 - $140. Andy's has these for about $50 plus shipping. http://www.andysautosport.com/products/tjm_equipped__66310R.html
Thanks Blade.... :)
Well ...I know that is difficoult to reply at one stupid question like mine ....
I am new about this part of world and in my european (italian) expirience I used the same springs configuration , with Koni shock.
I am In Mexico (baja sur) and here is difficoult and expensive to purchase everything for to make some test and after to improve the suspension "kit".....
So thanks for your suggestions I think that I will have risk something.....
Again:
Your 80 doesn't need any mods to enjoy it. If you leave it stock for a while, you will be able to make better decisions about what mods (if any) you want to make down the road. It sounds like you're pretty experienced with other rigs, so you may already have a good idea what you want. I'm lifting my 80 partly for looks, and partly for extra clearance. There is nothing wrong with making mods for looks. If you're just in it for function, stock functions pretty well.
Keep in mind that if the original coils are still under the truck, they are by now very poor, pale imitations of new ride performance. Coils age badly, compared to other spring types. You can get a set of stock height OME 861/862 coils very reasonably. As others have noted, no real lift needed for back road exploring and much more with the 80. The factory stock Tokico shocks are also priced very reasonably and perform great, although a shock replacement is not necessary with the 861/862 combo. Best of all, caster correction isn't needed, which saves cost and aggravation. In 4 hours shop time or thereabouts you can have a much better ride. Budget doesn't seem to be much of an issue for you, but when great is cheap, spend the saved bucks on other goodies.
