Surging Idle when braking
What @gnob and @bkg said. If it only happens when you step on the brakes it could be a vacuum leak at the brake booster or the hose to the booster. Good luck and please follow up with your fix. Dead end threads suck.
I also have a pretty sever misfiring, the truck seems to run on 3 cylinders. It can shake pretty bad. Last night I struggled to make it up a 65ft bridge from a light at the bottom.
Could the misfiring be connected to the other issue?
