As below, the FSM specifies a tolerance for the difference in level between the roof panel and sunroof seal. It does not specify whether the sunroof seal should sit above or below the roof panel, but rather just the absolute difference between the two surfaces.
For those with a sun roof that's believed to sit as Mr. T made it from the factory, which sits higher, the sunroof or the roof panel?
As of other note, there appears to be a redesign of the sunroof seal. Pictured below is the factory sun-baked seal versus a recently purchased replacement from Toyota. Despite clear and properly attached drain tubes mine still leaked leaving only the theory that the dried out seal allowed more water to pass than what the drainage design could handle. The leakage was verified to originate from the sunroof as opposed to the sometimes blamed windshield.
