Suddenly Slow...
Okay, new EGR installed now too...still not much of a change after putting some miles on it. With new EGR modulator the truck ran better, but that mostly translated to smoother power delivery.
For reference, at Sea level driving up an 8% grade hill from a stop I can get up to 30mph and just barely maintain that speed, no acceleration.
You sure you don't have something really stupid going on like carpet pushed up behind the gas pedal? When you floor it has some one checked that the throttle is 100% open?
I'm going to be get a friend over tomorrow...that's about all I can think of at this point, something screwy with the throttle and it's not opening 100%
I flushed the transmission and checked the torque converter too just as an aside.
Unless the exhaust shop physically pulled tour cats to look inside them, there's no way they could have "checked them". I'd say hit a smog shop and see if they can stick the sniffer up the tailpipe. (If they're bad, great time to upgrade to the magnaflow downpipe and cats!)
The exhaust shop drilled a hole in the pipe and looked at the cats with a scope and to test the rest of the exhaust they put pressure through the hole out the back (from what they said).
It did pass smog very well about 4 months ago.
I reset the ECU after every change I make, I have a quick disconnect on the battery so I just flip that switch.
Oh...I'd pull the cats myself, but the bolts are basically just a rusted mess which is why the shop opted to drill the hole. He'd have happily just replaced the cats, but out here in CA that's a $1,000+ repair bill
15 amp fuse will do it.
Mine only does it if I remove the positive, the negative won't get it to reset.
Are you running dual batteries?
Electrically there is no difference between removing the positive or negative off the battery in a single battery system. Electrons don't know the difference. Zero potential is zero potential any way you slice it.
I'm running 1 battery; and I'm telling you what I know is true on my system.
Removing the negative terminal alone never resets the computer.
Does your battery have dual terminals? 1 SAE stud and 1 for accessories for both + and -?
Did about 1200mi trip this past weekend and topped out about 6500'.
Sometimes the truck had full power and could easily climb grade at 50mph and other times barely get to 30 on the same road. No noticeable change in shifting or driving (other than power loss) inbetween. No more gas smell at least I guess, but now I'm more confused. Gas mileage when power was low seems to be worse (9-10mpg vs 11-12). Otherwise she ran great.
Is there a sensor somewhere I'm missing? No CEL, but with OBD1, who knows. Is it worth trying to get an ECU from a 94 since some 93 have issues?
I don't know that getting a 94 ECU will help; buddy of mine has a 94 and is going through a similar problem.
Are you running the stock muffler? I noticed a loss of power on a recent drive up to about 6000' elevation. My exhaust sounded like a high pressure air nozzle going up the hills... thinking bad muffler on mine.
