Suddenly Slow...
'93 FZJ with 260k on the clock (new head at 220k). It's driven fine the past 3 years I've owned it, but on a recent 800mi trip (from sea level up to 10,000' and back) the truck slowly lost power over the course of 1 day. It drives perfectly fine, but has about half the power it had when I started. No check engine lights and the only symptom is the occasional smell of unburned gas when I stop and turn the truck off. For example, I have to keep the truck floored to get it from 60-70MPH in a reasonable amount of time and it has trouble maintaining more than 50MPH at any reasonable incline. While offroad around 10,000' I had to put it into 4Lo just to climb hills not because they were tough, but I had almost no power. I've since put about 200mi on the truck trying to diagnose and drive it around with no change.
- Checked the cat, perfect shape and backpressure is good in the whole exhaust system (per shop that specializes in exhaust)
- Checked O2 and all good, but replaced anyway
- Checked fuel system and all good from the tank forward, good fuel pressure and all injectors seem to be operating properly. New fuel filter.
- New spark plugs, air filter, etc. and plugs all looked uniform when taken out
- Checked wiring harness near firewall behind EGR and all looks good, not brittle at all.
I'm out of ideas and searched the forum which mostly seemed to say "bad cat" or "bad injector(s)", both which seem to test out just fine.
Any help is appreciated!
Charcoal Canister
Fuel filter? Air intake Vacuum leaks into Intake maifold or assorted vacuum hoes?
Loosing power at altitude is perfectly normal but you will regain it back at sea level. Are you back home and still have the power loss? Clogged cats will do that.
Yes, back at sea level for at least 300mi now with same issue (power is better than 10,000', but still bad).
Charcoal Canister is something I haven't checked yet, I'll run a test on that!
Vacuum seems good over all and haven't been able to find any leaks yet, but that's worth continued exploration.
KevinNY said plug catalytic converter, I actually had that happen. Any resrtiction in exhaust gas flow will dramatically reduce performance.
If it were me, I'd pull the negative battery terminal for a few minutes and re-set the ECU.
Have you ever changed the fuel pump pre-filter in the tank? These are known to clog over time and collapse on themselves when the fuel gets warm.
Resetting the ECU as mentioned above is always good practice whenever engine maintenance is done, but simply pulling the 15 amp EFI fuse in the fusebox is a less invasive way of doing that.
Air filter is new, fuel filter is new.
Pre-filter in the tank I haven't checked. Charcoal canister/evap issue I'm going to look at today, especially since it has smelled like gas at times and I do get a lot of pressure release when I remove the gas cap. I unhooked the battery yesterday afternoon just in case and I'll see if that does anything.
Thanks for all the replies guys!!
if the cats are clogged they will glow cherry red. Been on the trail more than once where the solution was too beat the crap out them with a hammer and blow the guts out the tailpipe. It gets you home.
Just put on a new charcoal canister, going to give that a shot and see if I notice anything different.
The cats definitely check out okay, had an exhaust shop check everything out to give it the thumbs up in case I missed something.
Finally got a good drive in. Definitely a bit better with the charcoal canister, also no more pressurethane built up in the gas tank. The EGR also looks like it's not working well in testing, so I'm going to replace that as well.
Timing is good. Otherwise the screen in the tank is the only thing left
I sorta assumed that if fuel pressure was good at the fuel rail under load, then there would be no issues with the way it runs.
Fuel strainer looked new when removed, I replaced it anyway with no change on the drive. The tank inside looked very clean as well, so that's a plus.
Replaced the EGR vacuum modulator and things seem MUCH improved. Hard to tell without a good long freeway drive, but on my test run tonight it seems pretty good! I have a new EGR as well, but given the cost and hassle of replacing I was hoping I wouldn't need to.
