Sudden temp gauge failure
48.493445, -116.881603
Website
www.orttauq.com
Just noticed my temp gauge has stopped reading at all...sits at the bottom of gauge. ScanGaugeII still reads normal engine temp.
Where do I start? All other gauges are reading OK. Where is the sending unit for the gauge vs. for engine management computer?
Thanks
Not sure if I would care if the gauge that really never reads correctly worked at all, but there are two temp sensors on the car. above the oil filter and to the right. Cicled one should be the one you want.
dsc_5800-resized-and-temp-sensor-jpg.1009086
As you see by the second pic, I was wrong, you need the other one on the left of the oil filter for the gauge.
Thanks. Unplugged the front one, gauge did not move, shorted to ground and gauge still did not move. Unplugged rear and got code 115 and CEL light.
What next? Is there a fuse for just the temp gauge? Like I said all others are working fine.
As a note I did install a Dakota Digital SGI-5E a few days ago to fix speedo read ing about 7mph low...can't be related can it?
My engine(s) looked like that once. A long time ago.
The 10A Gauge fuse in the number 2 Fuse Block has this gauge. It's shared.
Here's the '94 EWD (the 95's the same; I don't have a 96-7 handy):
Check the sender using the FSM test. If that is ok you move to the gauge cluster. Check the temp gauge in the cluster using the FSM test. If that is ok check for continuity of the wiring harness from the sender to the gauge.
