Subwoofer Mod
Portland, OR
So I got sick of having way too much treble in my 80 and noticed the factory sub in the back and thought that I might be able to mod a new one in the area. So this is what I came up with.
I originally wanted to keep the factory grill. However, only going up to a 8" sub I still was unable to maintain the factory look. I like the way it turned out though.
I bought the sub for $30 from my buddy and we spent the afternoon building the box and mounting the sub. It took a few tries to get it to fit and all the body plugs to snap back into place but it worked.
I used MDF, screws, liquid nails, and expandable foam for the final seal between the side panel and subwoofer. Let me know if anyone has any questions.
Sound
It sound's great. After I filled the air spaces (expandable foam) between the sub, panel and box it sounded just like if I had it in a truck style box in the back. It doesn't pound and rattle your eye balls it just sounds good. All I was trying to accomplish was a little bass to accompany the ridiculous amount of treble and that is exactly what I got.
From one Portlander to another:
You might want to seal that particle board somehow. When (not if) your rear slider windows leak, that particle board is going to soak up water like a sponge and ruin that box. Otherwise, looks good.
I just installed a new amp and built a new amp rack board in the same spot and I'm still trying to figure out how to keep them dry in the event of water leaking down into that area. I've sealed up the bolt holes for the window trim, and it isn't leaking at the moment, but I'm not sure I want to risk it.
That's an 8" sub, right? I just wired up my new 8, and it sounds good. Nothing window rattling, but nice. I like how you didn't lose any real cargo space with that design. There was a real fancy fiberglass enclosure available for a while from one of the board members that put the speaker behind the trim panel in the same spot.
