Sub fuel tank Problem
Hi ,
I have 93 model , and i can't use the sub fuel tank !
When i press the switch , it's blinking for one sec. and off again , i changed the switch but it's the same ,,
any one have an idea what is the problem ?
Thanks
Need more info like has it ever worked, is this a new install, stock transfer pump, George ECU, etc.
On just what you gave me it woyuld seem the ECU thinks the tank is empty and won't turn on the pump.
If you take the sender wire from the tank and disconnect it, this might be a way to test it.
Forgive me if this is a stupid question, but is there a subtank installed?
Yes it was working b4 , and it came as an extra option from the dealer ....
and yes there is a sub tank :) , and it's full but i can't use it at all :crybaby: now .
Check your fuses and then check all the connectors. Start with the one that connects the fuel transfer pump and solenoid to the side harness (should be outside, under the edge of the vehicle, beneath the US driver's side passenger door...white 4-wire flat connector. The connector that serves the tank is easily traced from the subtank back to the rear frame cross-member. Both of these connectors look prone to getting dirtly and wet (as I contemplate my subtank install.) Lastly, on your truck, there is a stand-alone fuel transfer ECU located in the US driver's side rear cargo compartment, behind the large interior trim panel, over the inner wheel well. Its a small metal box with a gray 18-pin connection into the harness. If you resort to parts swapping, you might check that.
Sounds like your sender may be bad. You can disconnect it from the ECU and fake the signal to the ECU to think its not empty. If this woprks then replace sender. Otherwise, could be a cable/connector problem or even a problem with the ECU.
Man, I'd love to add a sub-tank, but the more I read the more worried I am about the install. Now I guess I also have to worry about the potential problems down the road. I'm a 1:banana: guy, so maybe I should just stick to the basics for now. I just wish there was someone here in the great state of Misery that has already done a sub-tank install. :frown:
After the ECU and sender you may also want to check the solenoid and pump. To check this you need to find the white and grey plugs as El Mariachi indicated and supply both with 12v to see if they will activate. I would think that the solenoid which is a one way check valve must activate to activate the pump when using the complete OEM system so that could be the source of the issue. I will have to defer to El Mariachi or Romer on this though because I don't know exactly how it works.
In response to the subtank install. I don't think its really a complex system. the most difficult part for me was installing the hard parts. Once that stuff is in the the wiring and such is straightforward. Any problems should be relatively easy to figure out.
The one thing lacking in this forum is any real data on how the non-USA OEM subtank assembly is wired up; and to complicate matters there are two different systems, pre and post 1/95. So there isn't a wealth of data here on Mud about troubleshooting the OEM system. One thing I have JUST figured out as I am working to wire mine up this afternoon (using the pre-1/95 ECU and wiring) is there is a wire running from the fuel transfer ECU to the D1 Data Link Connector (located in the engine bay on the firewall passenger side on US trucks.) This would suggest you could troubleshoot the system using the method described in the factory service manual, which involves shorting out the two ports in the DL connector with a test light and counting the flashing light sequence.
If the dealer installed this item, isn't there a set of documentation that came with it? A "flashing" light means something and this manual should explain it.
I don't think we're dealing with a US spec '93 80 series... Maybe a real factory subtank?
What country is said '93 with subtank in? Which country was it originally sold in?
