Stuck Shackle
Dallas
Website
www.octagonmma.com
Passenger side front shackle won't budge. I have been pounding on it, to no avail. I gotta remove the rear axle too, so I unbolted everything back there, hoping to remove the axle and leaf springs together. Is this possible?
Yes you can remove the rear axle and leave the leaf springs on the axle.
PB blaster or heat.
anythings possable
put some heat on the bushings as long as they're rubber.
burn them till they flame, pins will sliiiiiide right out.
I had the same problem last weekend; I used a chunk of 2x4 and a bottle jack braced against the opposite spring perch. Applied pressure between the perch and stuck shackle and hammered on the shackle perpendicular to the force being applied by the jack (shackle was bound up); hammering broke the rust loose and it popped out. Might be worth a shot before setting off the smoke alarm ;)
You wont re-use these old rubbercrap anyway, i guess.
Drill some holes in the rubber and soak it with WD40, no stink, no flames, just pure enjoyment, these bolts will come out like nothing.
I just did another suspension install this weekend.....after getting this tip with my steering stabilizer install...my new favorite tool is the tie rod remover or pickle fork. Just stick it in between the shackle and the spring perch and start smacking it with a BFH....it'll break loose. The pickle fork also worked great for the frame pins....
I used a combo of all of the above. First heat (makes life a lot easier!!), then pipe wrench to break it loose, then pickle fork to start driving it out. By the fourth shackle I was pretty good at it.
Good luck.
BURN!!! I tried bigger hammers,vise grips, pickle fork, nothing would quite do it, but turning the rubber into carbon made it a lot more forgiving. how drastic the measures will be to remove them probably depends on how long the bushings have been in there, mine were in for a looooong time I think.
got the top rear shackle bolts out with the air gun, and tapped the small bolts in front to move them a bit. Sprayed penetrating oil on them and will tap some more tomorrow AM.
I took apart my fj55 30 year old steering last weekend and wow that was fun, I used a torch and held it there until everything was basically smoking, hit it with some PB blaster while it was still hot, even more smoke, and proceded to beat it like a red headed stepchild, it came apart.....
Noah
now I need some damn springs!
who sells the best ones or do I have to retrofit some 4 ton truck axles or something?
muahaahahahahahahahahahhahahahaa!
