Stuck on the trail...
AZ
Spent the last nine days up in the mountains at a friends cabin for some fishing four wheeling and fourth of July celebrating. My friend has a 78 CJ so I was anxious to show him what the 80 could do. First full day up there (after hangover recovery) we took a bunch of the kids for a little trail ride nothing too radical but we got dusty and picked up some new pinstriping. Everthing worked and we had fun with the kids. The next day he and I went in to town to get some ice, needed for more cocktails, and I said " you want to go look at that trail you said you know about" so with two bags of ice we go looking for a trail head to see what it looks like. We found the trail, nothing too bad at first, then we came to a gate went on through this is where the fun started. The Forest Service at one time had deciced that they didn't want much traffic up this road and put about six big humps of dirt spread at various intervals across about the first 1.5 miles of the road. These bumps obviously had been driven over many times but some were still pretty steep and pointy. For those about to flame there were no posted signs or any other indication that this was a no motor vehicle travel road. We got over all of these bumps at the expense of my already bent running boards. Those things are not designed to be rockers. :hillbilly:As we approached the top of the trail we came across another hump this one was not even as big as the others we had already encountered as we went over the top and started to come down we hit something hard and the truck stalled and would not start again. It was cranking but no fire, open hood everything looks good, can't see anything obviously broken or disconnected, no fuel leak?? We push the truck off of the bump we are stuck on and coast it back into a little clearing to get a better look at things. Tried to start still no go, crawled under truck still see nothing wrong except a bent cat, exhaust is already screwed up have a chain holding muffler out of the driveshaft.
On a wild ass guess :idea:start looking at fuses under dash, then in fuse box under hood and I be damned but the 15A EFI fuse is blown. Pull the one for cig lighter and stab it in the EFI slot and the truck starts running :bounce:very rough at first, wouldn't idle.
We start back down and re-negotiated all of the obstacles we had encountered going up with no problems and got her back on pavement. Cell phone starts blowing up because the wives want to know where the ice is and wtf we have been doing. We dump the bags of water we are now carrying and go get more ice. It was definately cocktail time. :D
The biggest problem now is it sounds like I have ricer exhaust, huge leak at the flange between the cats and I have a CEL that I assume is from the exhaust leak. I sill can't figure out why that 15A fuse blew?:confused:
You could have jarred the harness when you hit, and that caused the fuse to blow.
Also, the ricer exhaust sound might go away if you take off the running boards....
Mine did, dunno why, but after bending the heck out of them in a similar situation, I thought for sure that it was new exhaust time. I removed the boards and there was no more sound.....
Beospeculation follows: Since the EFI fuse failed concurrently with a big bump, my guess would be a short in the wiring harness going to the O2 sensors. This would account for the rough running and the CEL. It is normal for the engine to idle fast and for the idle to "hunt" as the ECM relearns the fuel mapping after the EFI fuse is blown.
Fix the wiring to the O2 sensors and you should be good to go.
FYI, those "gates" or "tank traps" are berms put there by the Forest Service. Their objective is to dissuade those with vehicles that are not capable. There are many trails in our area with these at the entrance. They will also berm the trail to help with erosion. Berms do not mean a trail is closed. Gates and signs are used for that purpose.
-B-
-B-
You are correct. I've seen this happen on another 80 I was wheeling with. What happens is you pushed the whole exhaust up when you hit the bump. The wiring harness and O2 slam into the bottom of your floorboard shorting it out. Blowing the EFI fuse.
I experienced exactly the same problem last fall, although I wasn't driving as hard as you. Locating the faulty wire is one helluva job, and I would leave it to professionals. Good luck :cheers:
No the first O2 sensor is all he needs to find. That is what shorted out.
Thanks for the info I will check out the O2 sensor. Now, do you guys have any advice on getting the wife to stop B!tching about the scratches and the bent running boards??:grinpimp:
Ask Beowulf about "Scratch Prevention"......
Yes, this is EASY.
The wife will quit bitching about bent running boards and scratches after you lift it 4+ inches, buy some real armor, add a winch, mount a big set of noisy mud tyres, and clutter the inside with radios, fire extinguishers, switches, bells, whistles, and the like.
And if she still bitches, add an expedition rack and open the sunroof at 70 MPH. I promise she will never mention scratches again and even if she does, you won't be able to hear her or much of anything else. :D
-B-
Right now B is hoping like hell that Mrs. B doesn't see this post....:D
Yes, this is EASY.
-B-
LOL.....thats funny B.:D
:cheers:
Sam
I agree but this wire seems to sneak in mysterious ways and can take some time to track down to the fusebox or whatever hub, if my mechanic is trustworthy (OMG, could I have been ripped off?)
Buy her one with lockers and keep it stock. In 10 years buy her something different and enjoy the then lightly used 22 year old truck as a trail rig.
Win win.
