Stuck in the 80!
Fingerlakes NY
WTF! The 6 months that I've owned the 80 I've been in more off road trouble then ever before!
A month ago I buried the cruzer in our yard after a heavy snow fall andbusted ass shoveling to get it out.
2 weeks ago I accidently slid into a 4 foot ditch that the plow trucks had covered up (no road shoulder at all).
Wed. I decided to cut some wood deep in on our porperty and spent 45 minutes trying to make a hill back out to the road. (the snow conditions changed , 2-3 feet of snow turned heavy and base turned to slush that + greasy mud) I thought for sure I was screwed and the only thing that was going to get me out wasa tractor. It was that I was stuck in one spot, just that I could'nt make it up the hill.
I have to admit that I hav'nt saved up the $ for better tires (the LTX's just don't cut it).
Does anyone else have this mentality that now that they have a locked 80 nothing can bring them down?
If you can get some 'lug type' tires your traction will be greatly enhanced...I would recommend some maxxis buckshot mudders...cheap tire, long lasting, very little road noise and a good lug....
mud tires are crapon any hard snow. you need chains. plain and simple. the solid axle pushes a lot of snow if its deep enough which gets very heavy.
get chains, seems to be your best solution.
Yeah I'd get chains, plus the 80 isn't the greatest mud/snow vehicle as they are very heavy. With the right tires you'd be okay though.
Mud tires in snow suck. I know. I nearly got stuck in 2' of fresh heavy snow ON A PAVED ROAD. A couple trucks had been through before me and left big ruts in the snow, I tried to get out of the ruts to avoid some tree rash... that's when I got stuck. All 3 lockers locked... and nearly didn't get out. Took me about 3-5 minutes of rocking back and forth Once I started moving I didn't take my foot off the gas, but didn't really have any control of steering (kept getting sucked back into the big ruts.) until I got into a more open area.
WTF!
Just so were clear here, becouse I thinks it's about a 50/50 mix that owners think they got "a locked" 80 when all they realy got is a switch on the dash that says "center diff lock" and a pretty light in the guage cluster.
Just so were clear here, they are not all "locked" ok?
Turn off the lockers when driving on paved roads covered with snow.
It took 7 years, 30" of fresh powder on the ground, several big snow drifts and some AT tires to finally get the LC stuck! Locked up the front and rear aired the tires down hit the gas and made it another block to get out of the deep stuff. The snow was so deep it was flying over the hood. Apparently Colorado ran out of snow plows and I felt it was a sort of public service for me to go out and break some tracks on some of the local neighborhood's. :D
Kid's, be advised don't try this at home without the lockers or a good snow shovel anyway!
Not all mud tires are equal. I have run this winter with trxus MT's in everything from icy hardpack to 4' of snow across my 200' driveway to narrow icy forest service roads on a family Christmas tree hunt to zero visibility ground blizzards in 50 mph winds on what would otherwise have been a sunny day.
We have had 10 feet of snow at my house this winter and counting, it's been 3 months since my roads have been completely clear and not melting and icing every night. I have not lost traction one time where I wasn't screwing around except bogging down in the 4' drifts after our blizzards. I have slid clear through a major intersection in my minivan on Nokkian studless snows (with 3 of my kids in the car missing a pickup truck by a few feet), but not in the 80, and the 80 is the vehicle that sees 99% of our winter use when conditions are bad.
Contrary to what others are saying, I think the 80 is an exceptional all condition winter vehicle if properly set up - it's weight, wheelbase, drivetrain, and selectable diff locks are all a huge advantage. I've been extracting people since October and I think every one of then would agree :D
Your problem is your tires. Chains are a great idea if you want to keep road oriented AT's and need emergency traction, but would seem to me to be a real PITA if you use your truck regularly out on your property.
But I don't feel invincible. I just test the limits when it is safe so I have a good sense of what those limits are - you've done the same and it is time for some real tires, I'd say.
I on the other hand need some real gearing :D
First thing I got rid of... those s***ty LTXs. If LTXs work for you... you don't need a landcruiser!
I mentioned chains, but I think it is worth mentioning that if you are offroad AND you get snow of that sort you REALLY need to ditch those LTXs for something better. I also agree with some things people have said...MTs generally suck in the snow. I don't think they all do. Most of the tighter lug patterns do. The larger patterns do not. I don't think you want to run a super swamper all the time if you have LTXs...talk about drastic change.
I would suggest you get a snow tire for the winter that you could run studs in (if you are allowed) that has some aggressive tread.
