Struts & AHC on LX570
tbisaacs :
When you replaced them, did you do an AHC flush / fluid replacement at the same time? Did you do the replacement yourself?
Just curious since you purchased the parts separate from the dealership.
tbisaacs :
yes do the fluid because you have to bleed all of the accumulators to do it and you’ll loose a ton of fluid doing so.
I had my Indy mechanic replace my shocks. Labor for all 4 was $800-ish.
I also had done a fluid flush prior. It’s not hard with basic tools and some patience.
tbisaacs :
Here’s a detailed walk through of the flush. Relatively easy (if a bit messy) process. You’ll probably need more than 5L of suspension fluid to properly pre-flush the new shocks (as other mudders have recommended).
Thread Bump.... I need to change my fluid. Hoping this will help the ride at 75 mph. Seems like I need shocks at 130k miles.
Read up on a few threads and placed an order for all 4 corners including fluid for the LX we just picked up [leaking front strut] . Figured I'd do it all at once, Toyota parts counter matched lexuspartsnow prices too.
Will try to document the process as I haven't seen too many post photos of actual strut removal etc. Going to pickup a 1/2in gun to make things a little easier. Could've used it when replacing my LS430 suspension a few years ago. Pleasantly surprised with total parts coming in under $800otd.
I don't feel any difference when I flip the console shock switch.
If you’re replacing the rear shocks, hope this helps!
Ya that helped. I'm going to the dealer.lol.
I flushed the AHC system and the ride in my 14 with 130 k miles is still the same IMO. When I move the switch to change the ride settings I don't feel a difference at all. I do feel as if there is better vehicle control at highway speed though. I haven't driven it much.
What does that switch actually do?
Replacing shocks/struts/actuators (whatever you want to call them) will likely not change your ride quality. They only have a small amount of compression built into them. Nearly all the suspension compression is happening in the accumulators. This probably explains why you don't feel a difference in driving modes. Sport vs comfort should be pretty dramatic. In my opinion, it's probably least subjective way to decide if you need to replace accumulators. At 130K I would not feel bad about replacing the accumulators. Especially if you can not verify the system was being flushed early in life. I plan on replacing mine at around 120K.
^ this is correct. All of the damping in AHC happens elsewhere. I replaced all four of mine and it made no difference compared to a fluid change.
Ok, I was just driving around in the truck today thinking, is this the best it's going to be with a 5k lb truck with 130k miles on it. I have no shock leakage at all. Maybe a longshot but, is there a fuse or plug that is in line with the sport/ comfort switch?
I'm pretty sure the fluid was never changed until it was done last week. I think I'm going to flush the system one more time and see what happens. The original fluid level was very low. I think I pumped out only about 1qt. and I was extremely happy to be able to brake open all the bleeders with out any trouble. Plus, I haven't bled the 5th accumulator yet. I didn't realize there was one until after I was finished.
It was my first time under this truck, so I cleaned up everything I could and painted ... One of my favorite things to do.:cool:
Soooo....I had my AHC fluid just replaced and flushed a month ago and NOW I am noticing a leaky front passenger strut.
Will this mean that I will have to flush the AHC again?
Please God no....
Please God no....
Hey, I may have the same issue as I see mine lowering on its own in the front a bit.
can someone please let me know if a leaky strut would have oil on the ground or just leak back into the hydraulic system.
thanks!
thanks!
If a shock was leaking you’d see it on the shock body. If you see fluid on the ground I would suspect the lines themselves. Also have a look at the accumulators under the running boards.
With shocks/struts does everyone go OEM or is there an improvement out there to be had while keeping AHC and what not?
OEM is the way
