While bleeding brakes, I found that the bolts holding my passenger side calipers were loose - and loose to the PO probably zipping them in with an impact driver. The threads in the upper hole are all gone, but the bottom hole is marginal. With brakes being probably the most important part of the vehicle I did some digging/searching on here Essentially there are three options:
- Drill and tap to 1/2-20 bolt size - opposed to this route, since everything else is metric
- Timesert - mixed reviews if you have to pull the knuckle. (Helicoils get mixed feedback for this application)
- Get used Knuckle, then would need to rebuild knuckle. Repair the old one for a spare while off vehicle.
