Strange "Wobble"
Tulsa, OK
Website
www.cardomain.com
I run a set of 1/4" spacers (yes can can see the difference) that have a slightly larger hub hole than the hubs actual size. Being the anal perfectionist that I am, I took them off the other day and put some quick dry JB weld on the back to "center" them.
After putting everything back together I took it for a spin. I immediately noticed a "wobble" (similar to braking when you have a warped rotor) at around 45mph. I knew it had somthing to do with the right front because that was the most recent one I had "centered".
Took the wheel off, checked for missing balance weights (none missing), spacer was still centered, put it back together, everything was smooth again. I don't get it.
Before you removed the wheel, did you make sure that everything was tight? I ask, because it could be that the JB Weld had not fully cured and seated properly when you put the wheel on; then perhaps the product settled in, which could have left a slight gap causing the wheel to come loose: when you put the wheel back on, you would have seated the wheel properly.
Just a wild guess...
Well, maybe there was a piece of material between the wheel and the spacer - again, a wild guess.
Doesn't matter much now since the wobble is gone.
