Strange aftermarket stereo issue
Lake Orion MI
Have a 1996 LC and have already installed the Pioneer TS-G1645 speakers in the front. Wanted to replace the factory radio with the Pioneer DEH-X6900BT, bypassing the factory amp, but am having a couple of issues.
First of all, I purchased the Pioneer deck from Crutchfield along with their ready harness, so all of the wiring between the Pioneer and the facory harness is taken care of. The first time I connected everything up, the Pioneer went into an endless electronic loop, showing the word "Radio" dancing across the LCD display. The only way this would stop is if I disconnected the plug for the rear speakers on the ready harness.
Another issue I have is when I am playing the radio, without the rear speaker plug connected, with the truck not running. As soon as I start the truck, that causes the fuse in the back of the Pioneer deck to blow. So I spoke with Crutchfield tech support and they had me connect the radio directly to the battery with just the power and ground wires and do the same thing...key in the second position (but engine not running) turn radio on and then have someone start the truck. I did that a half a dozen times with no fuse being blown.
So, the radio will not function at all if the rear speaker plug is connected and the fuse blows in the radio if I start the truck with the radio on. Crutchfield is thinking that something is wrong with the speakers and/or the wiring, even though there were no issues with the factory stereo. Oh, we also swapped out the Pioneer 3 times with the same model and two of the ready made harnesses to rule out defective components.
Are these newer radios more sensitive to older vehicle electrical systems? Anything else you would check before I go thru the process of connecting each speaker, one at a time, and seeing if the fuse still blows? Maybe try a different model or manufacturer of radio?
Thanks in advance,
Eric
Did you actually unplug the amp, are you using the two plugins for after market stereo or running thru the one big plug behind the dash
I am using the two gray connectors on the factory harness, along with the Metra 70-1761 harness that has been prewired by Crutchfield. I am not using the white connector that was originally used for the factory stereo. And no, I have not physically gone to the amp behind the glovebox and unplugged the connections. Per Crutchfield, they said it wasn't necessary.
Was your old stereo working prior to this?
Is your new piece a pre-amp or self powered unit?
Also check make sure the power antenna wire from the new stereo to s not hooked up, antenna revives its power from different source so that wire should not be hooked up
Is there any trick to removing the glove box door? Can't seem to figure out how to remove it.
Two screws at the top in the left and right corner of the door when opened.
I have a sony mex something or other, it has powered sub amp outputs and uses more juice than the wiring harness would be able to provide. It's wired to the battery (along with a CB I installed at the same time). Both of them share an "ACC" (accessory on) line as well, so when the key is at ACC or ON, they will close the circuit and consume battery juice. My (powered) sub in the back works the same.
Not sure if that's at all helpful, but it's how I configured things.
yes, Unplug the amp and run new speaker wires from the radio to the speakers. If your savvy enough you can run the speaker wires from the radio to the existing speaker wires from the Output of the factory amp. Im not familiar with the 96 wiring so the speakers may have a common negative/ground.
Not wanting to run new speaker wires at this point. Just want to use existing wiring and bypass the amp for the new head unit.
I did NOT unplug my amp, I have ran two different Alpines in my 1996.
what I found though, was the small 22 gauge wire in the factory "aftermarket" plugs that the metra uses [ I too use these, but made my own to the Alpines harness] the wire was NOT big enough to carry the current required by the modern stereo's.
what I did was run a 10 gauge fused wire from the battery into the center dash to a generic 20/30 amp relay and then to the wire that powered the stereo, while the small 22 gauge wire from the harness now "activates" the relay coil when the key is turned on.
this gives you clean 12V with adequate current to the stereo and will let it function as normal. As far as the rear speaker problem, I would verify the wiring from the pioneer side to the Toyota side of the prebuilt harness, as it sounds like maybe it was just assembled wrong, the metra harness should be labeled [ tiny tiny writing on those wires] and the pioneer manual should also give you the correct plus/minus rear speaker colors
I used the Metra Harnes and an Alpine Head Unit, and unplugged both amps (rear in Passenger Compartment too) and never ran a wire. I too have the Pioneers and it's a great improvement over original.
IDK what brand harness / pigtail I have, but buddy has installed an Eclipse, a Excelon, 3 Alpines in my black 80.
I know my amp plugs are out, I forget but may even have the amp removed.
Also, I forget exactly how wired, but a relay was used & my stereos have all acted like factory remembering how far you had the power antenna extended when you switch to radio. It got added back with the Eclipse HU, maybe they are a weird configure.
