Stranded, I really h8 mud.
Truckee, Tahoe, CA
Today after a day of wheeling at Prairie City OHV my 93 died. About 30 miles after wheeling, my A/T Fluid Temp light came on, a few miles later, the ABS light came on, then the Check engine. I pulled over, turned the engine off and it wouldn't start. Got a jump, it started but a few miles later, the RPMs dropped and it died. Got it towed to the Auburn Toyota dealership. Any ideas or suggestions?
I just had my alternator go out last week. Changed it yesterday. Prior to it going out, my AT TEMP, BRAKE and Battery Light all fickered in unison before it went. I tought I had a short in my dash. Someone here said it was a sign my ALT was going bad. They were right. Next day it died. Somesaid the three lights flickering was a code the ALT was bad. Might be your problem too.
I bet its the ALT then. Thanks.
I'm curious how much the dealer charges you. Read my post: An angel knocked on my door. Found out my neighbor is a ex Toyota Tech.
What was the voltage gauge doing during all this?
No, I wasn't drifting it.
The Auburn Toyota called me and quoted me $570 for a new alt and labor. I told them don't touch it. I bought an alternator today and tomorow I'm just going to put it in myself. I'm heading to the FAQ now to see if there are any good write ups. My mechanic assured me I could do it myself however.
The same thing happened to me before the alternator died, I bought a new alternator two months ago and last week it happened again, as soon as it happened i turned aroung and went back home, on my way back it keep blinking on and off, the voltage gauge was in red and all the lights on. I figured my alternator is dead again, but before I got home the lights went off and everything was back to normal, any ideas why this might happen???? How often does an alternator goes bad?? Granted I was crossing water but I don't think they are supposed to die that often!!!
Last time it died I was crossing water and some mud and I used my winch to help a friend of mine while being super stock!!! PLEASE HELPPPPP!!!!
Is it a shortcut??? What can cause this problem?
What brand?
I installed a 170amp aftermarket alternator about 7 weeks ago!!! :bang:
Right now is working fine, but I'm gonna be so upset if I go out again and hit water or mud (being that I live in Florida and there's a Tropical storm going on right now :p) and it happens again!!! Does this happen often or there's something else I should be looking for that causes this problem???
I'm having the same behivor in my 99 Autana, suddenly the bat light ( on V dash indicator ) and air filter come on .. suddenly disappear ..
I was reading about the fusible link .. but las sat I was working on that checking al plugs and conections, also make a solid wire from the alt to the bat with a 80 amps fusible, but nothing still the same behivor.
This sat I will go with the alt again to the alt shop and see what happend ..
if you hit mud/water a lot, maybe there is some way to fab up a splashguard for the alt?
You might also benefit from pulling off the various connections, cleaning them up, then greasing them with soem silicone grease before you put them together. Can't hurt.
