If you have had any chemistry education, this should make some sense.
Rust = Fe3O2
If you do the stoichiometry, you'll find that a reaction with phosphoric acid (as well as hydrochloric acid) will result in FeO, which is neutral (that's the black stuff the everyone talks about). You'll find that all rust converters/inhibitors/etc contain one of these acids in low concentration.
If you know anyone that works in a hotel or other commercial site, they can get stuff with higher phosphoric acid concentration. I used Johnson Diversy's Suma Scale to remove the mill scale from new steel.
I's suggest that you sandblast rust off, that's by far the best way.
Another piece of helpful info... Urethane coatings are generally moisture cure. When you put them on oxidixed metal, you have the potential to remove the O2 from the reaction. Once that happens, the rust can't continue. My guess is that POR is a urethane based product, but the situation is different in every installation (it works for some, but not everyone) because of the amount of O2 that must be reduced.
Best bet, as noted above, sand blast, then follow with a good 2 part urethane coating (see any automotive refinish outlet). Let the datasheet show you how durable the product will be. Don't bother with enamels or lacqures.
It should concern you that POR does not adhere well to clean, rust free metal. Without question that is the optimal surface for professional coatings that will serve you well for the same or less cost.
...just my opinion
Rust = Fe3O2
...just my opinion
