Wanted Stock wheels
Post an ad in the general classifieds as well if you haven't already. 40 series rims are the same as the 55. You should also specify if you are looking for '72 specific rims, which are riveted, or the later welded rims ('76 and up IIRC).
Thanks. They're for a 71/ 72 . (The one on the right)
I understand that but both will fit your 55 and both will look more or less the same. As already said, the difference is with the later welded rims you can convert the front to disk brakes. The riveted rims won't fit over disks. If I were you, I would open my search to both. You won't know the difference once they are installed.
Thanks for the tip. Disk brakes would definitely be an improvement
