- Thread starter
- #41
Yes, the Michelin Defenders in P275/65/18 (116T) are considered an outstanding tire. I like mine but the look is not "cool". I've never had the stock Dunlops but I assume the softness is comparable. Note my size is one higher and a bit narrower than OEM, but if you leave the spidertrax (which I don't think changed the ride) the 275 width is fine. Spidertraxx are not needed at that size, but the look of the LC is better with the tires less inboard (in my opinion of course). I run stock 2019 LC wheels with 1" Bora hub centric spacers.
That said, the height difference isn't huge vs stock Dunlops. You can compare here but there will still be variations by brand: Tire Size Comparison - https://tiresize.com/comparison/
On my 275/65/18 Defenders, on a 2013 LC, the size change made my speedometer dead on with GPS speed, FWIW. The Defenders handle well, are very highly reviewed, and seem to last forever.
If you want a little more "fill the wheel well" look and stick with P-rated, the primary (only?) option is the General Grabber APT P rated 275/70/18 (the stock tire and size on some Nissan Titans). https://www.tirerack.com/tires/tire...GRAPTOWL&vehicleSearch=false&fromCompare1=yes
Thank you. Very helpful. Your set up is where I’m tracking. I have the 1 inch bora’s on way. Would you mind taking some pics of this setup?
Sounds ideal — thank you again.
