Stock running board ideas
I painted my FJ40 in 1990 myself with a single-stage enamel, and have tromped on the running boards (as have my passengers) for 70K miles since then, and the paint is holding up well on them - just a few small scratches. Unless you stand on your running board with sandy feet and do piroettes, I think you'll be ok.
Years ago, I bought an aerosol lower-rocker panel clear finish for a different application. Something like this: SEM Products Chip Guard SEM-39813
That might be a simple way to add some film thickness to the surface so that your shoes don't immediately hack into the paint. If you do bedliner, at least make it color-matched, rather than black! Just my .02.
Steve
Do you have 1962 style running boards with the rubber tread material inside them?
I'm not really sure on that, but the running boards do have a white flakey substance under the trim ring. Maybe what's left of the rubber tread? I do know that these were more than likely stock as the paint matched the truck.
Started working on the running boards. Found a thin gasket sitting on top of the white stuff which I think was what's left of a foam adhesive sided strip. Here's is what I found on the first one:
