For Sale Stock 1971 FST FJ40 Austin, TX
Austin
Non-restored, but very cared for and maintained FST 1971 FJ40(build date 9/70). Solid, straight and honest. This rig originally came from Chino, CA and has resided in Austin, TX the last 10 years. Don't think I've ever seen a taligate, rear sill or tub this clean on a non-restored rig. I have a binder of receipts dating back to 1997. It had a respray in Pomona, CA in 1999. While the paint isn't original, it presents itself as thought it is and retains a dull shine. At the same time, the inner tub was painted with what appears to be flexstone paint, NOT bedliner. There are couple of small/surface rust bubbles on the driver rocker and just below the rear emblems.
It's running the original F engine, but had a documented rebuild on 9/27/01. Pistons, rod bearings, cam bearings, cam reground, crank reground, new timing gear. The F pulls hard and runs great. Stock carb was replaced with a Weber; however retains the original air cleaner. 6 to 1 header
Drum brakes, 3 speed transmission with vacuum actuated 4wd. 3 on the tree was converted to floor shift. The transmission and transfer case were replaced in 4/21/09. All documented. At the same time, the clutch, rear main seal, throwout bearing, oil pan gasket were replaced and the flywheel was resurfaced. Vacuum lines replaced on the transfercase. Everything works as it should...all electrics, all lights, wipers, horn etc.
Upholstery is in great condition and was redone on 10/5/98. Unfortunately the original soft top, bows and doors are no longer around. The Bestop Tiger Top is in fair condition, couple of cracks in the rear driver window. Rear heater has been deleted, but one will be included with the sale.
Recent work: new radiator, water pump, 6 blade Toyota plastic fan, points, Denso plug wires
Needs: muffler
Price: $16,500 PM me in you are interested. I can help arrange shipping if need be
More
More
Last ones. I have plenty of other photos. If there is something specific you want to see, let me know
Monday morning bump! Willing to negotiate on price if any MUD'ers are interested.
Dude, you've certainly got me tempted. I just sold one of my 80's last week. I've wanted a 40 for a long time.
@redeye this is a good one to either drive/enjoy as is or make what you want. I think it is perfect as it sits, but that's me. PM me if you are interested and we can chat about it. I can also help arrange shipping to NJ if need be.
@redeye if you bring it to the northeast I hope you plan on storing it when the salt comes out!
Sold to @redeye
She’ll be heading to New Jersey next week. Cheers Ed!
Check the mudship section for reliable shippers... Or: Epic Roadtrip!
