Still adding oil?!
Monroe, GA
I don't have any spots in the driveway, and I haven't noticed (sight or smell) any indication that I'm burning oil; but, I'm adding two additional quarts of oil in between 3,000 mile oil changes. I am coming up on 225K on the odometer.
Sounds about right. I wouldn't worry one bit.
Ok, I'm feeling a little better now. The mechanic who replaced my leaky valve cover gasket told me that an engine in good condition can still "consume" a certain amount of the oil in normal operation. I just didn't know the girl was that hungry. It reminds me of a country music song a friend of mine wrote about his '68 Camaro: "She Smokes a Little and Drinks a Lot"
Sometimes switching from conventional to synthetic or vice versa can make a difference on oil consumption.. same story for a slight change in viscosity. If it bothers you at all try switching something up with the oil and see if it makes a difference.
I changed from whatever the po had in it to 10-40 high mileage Mobil one and my oil use went down slightly. I use about 1qt per 1000 sitting at 220k, original head gasket
I usually carry about four extra quarts of oil after I do an oilchange. When all four run out, its time to change the oil again!
You are not alone. I use Rotella T 15w-40 and have same issue. I am the original owner and I'm at 245K miles. I also have a rebuilt 2000 F-350 crew cab dually powerstroke and use the same oil and she drinks a quart or 2 between 4k changes.
I've got 6000 summer expedition miles on my current pan-load and haven't added any oil! Sorry.
They are all different. A quart or two at 3000 miles on a high mileage truck is nothing. Drive and enjoy. Oil is cheap.
Some seem to use no oil. Others seem to use a quart per 1000 miles. Toyota says this is all normal.
For me, I change at 5k intervals and am down about 1/2 quart. At 150k miles. The only car I ever owned that used no measurable oil was an Acura.
My '97 LX seems to use oil more than I like, although I do know the two seals up front are seeping. My two '96s and 100 series with a combined 960k miles uses zero oil.
I guess I'm lucky, mine doesn't use any oil between oil changes.
Sealed up all the oil leaks on my rig with 251k miles on it, minus the rear main seal, need to add a qt about every 500 miles. Original HG and valve seals... Normal is my understanding.
I use 1qt every ~1,500 miles. I believe the owners manual states 1qt every 1,000 miles is acceptable.
