Once you have the unit removed from the gauge cluster, pry off the needle and remove the two small screws holding the printed face of the speedo. Then to separate the trip meter from the unit, release the clips as shown in the original post. That should give you access to deal with the gears and the broken partHello LTrain,
thank you!
I actually meant the fixation of the small trip meter shown in the picture above - as part of the full Speedo Cluster. You are right, the full cluster is fixed with small screws.
But how to get out the trip meter from it? Via the front, I.e. removal of the needle?
As noted in my previous posts, there can be some trial & error to get the needle back in the correct position to show accurate speed.
