- Joined
- Nov 22, 2010
- Threads
- 44
- Messages
- 2,151
- Location
- Wilmington, NC
- Website
- www.kindredspiritscsg.com
- Thread starter
- #421
Last night I made use of the bead blaster I just found out was available for use in the shop.
Throw an inch or two longer shackles on there and call it good. That angle will be no good with weight on the truck, but with longer shackles, you should get a good overall angle with wicked flex.
shorter shackles will lessen the angle, not longer, that said I would just move the hangers. I would throw the body on and see what happens but it will probably be too shallow of an angle and may top out at the frame under compression before you hit your bumpstops. you're gonna need axle shims to cure your pinion and caster plus longer U-bolts than the stock fronts as well.
nice job, the black looks good but you're gonna need window tint and a murder job on the chrome.
This leads up to one of those... if I'm in there I might as well __(insert cash)___. Ultimately that leads to a rebuild.
At least inspect the head for cracks anywhere, cylinder condition, etc. Hopefully no worms come out and all it needs is a gasket.
Good point, I really just want this to last until I can put the 6BT in. I'd rather spend money on that.![]()
