Steering wheel shaking
I have that crack right now...it is a real possibility! After I fix my front ring and pinion I grind and weld to fix that crack...joy!
Can you post a pic of the crack?
Old thread but @cruiserfj45 this could be part of my problem. Definitely weeping driver side knuckle. Will check steering box area.
I had a similar problem, I tried all sorts of things, it finally turned out to be not only worn panhard bushings but also the RH mounting for the panhard has a nut that is welded on the back of the clevis it goes into due to being almost inaccessible, mine broke loose and was causing even more wobble, the fix was to have that nut tack welded so we could remove the bolt and panhard, and to properly weld that nut back in place, and replace the bushings. It's all solid again now with no wobble.
