Steering Wander
Bismarck, ND
I recently purchased my 78 FJ40 and it has a steering wander issue I'm trying to figure out. From everything I read, it's got all the symptoms of the caster being out of alignment. Basically wanders bad on poor condition and rutted roads. It's got the Saginaw power steering, 4 1/2" shackles on the back and stock shackles on the front, and 32" tires. Will caster shims fix my problem?
I would start with toe in first, grab a cheap curtain rod or get a helper with a tape measure to put across the front of the front tires at axle height and measure, then repreat at the same relative spot on the rearward side of the same tires: diff should be roughly 1/8" shorter in the front. If toe in is good, then you can move on to TRE's and caster. Good luck.
Wandering can come from toe in or caster being off.
Most caster problems come from long shackles in the front.
Since you don't have long shackles, I'd do as mustard suggests and start with the toe in.
Wandering
The guys are giving you the correct information on were to start as I just had the same but I took the rig to an alignment shop to get the right poop on the complete front end settings- toe, Castor, turning angle without messing around and found out I was 1 deg neg. Did not cost much as you only have the toe-in/out to set. Do check your wheel bearing with the wheels off the gound.
With the help of the guys on this site and a bit of math I installed 4 deg STEEL shims, now I have complete control.
Well worth the work and money.
Steering Wandering
All of the above, plus:
(a) Running slightly more air in the front tires puts less rubber on the ground, consequently steers/tracks better (but don't do this to the point of stupid).
(b) Heavy duty steering stabilizers help, but unfortunately they are very perishable, most presently on vehicles were worn out many moons ago---has to be fresh.
I have a question on this topic- all things equal, wouldn't you guys expect more wandering as you increase tire size?
I've noticed this on every car or truck I've added wider or taller tires to, even after alignment (a mercedes, a bmw, a jeep wrangler, and an FJ40). More specifically, the vehicles tended to hug ruts in the road much worse, especially at highway speeds.
I figured it was due to the extra leverage the tires exert against the steering components when they encounter a rut or a bump.
Should I expect my 40 with 35x12.50's to resist wandering as well as a stock rig (again, all else equal)?
Don't know the answer to your question, but I can say I'd love it if my FJ followed the ruts. At least it would stay on the road! Right now, I'm only running 32's and it will hit a bad spot, kick one direction and start heading that way. Gets worse with higher speed. Pretty scary sometimes!
Thanks for all the great advice. I'll make sure to post what ended up fixing the problem!
Checked the toe in, and it was spot on. Checked the caster and it was 2.5 deg neg. don't ask me how. Put some 4 deg shims in and it tracks straight as an arrow now. OK straight as a 1978 arrow.
OLD THREAD ALERT
Newb Question: Can someone please explain where these shims go and does the alignment shop keep these in stock?
Yes.
No.
OLD THREAD ALERT
shims(wedges )are going between the axle and leaf spring...I do have 4" lift and wedges needed to be slide on front axle from the back to put the front diff back down....On the rear axle shims needed to be slide from the front to do the same thing-keep the pinion down to be more paralell with the angle on front area of driveshaft...I used bigger (taller)shims for 4" lift...You can order shims from Valley hybrids(steel) if they still sells them or aluminum from CCOT or Cruiser corps etc...
Wouldn’t a good alignment have the shims? If I have no idea what size is needed it seems like I would be guessing to order from someone.
A good spring shop will have them... but most shops that do alignment would need to bring them in. Around here they could likely get them within a couple hours. Or they could possibly measure up your rig, and you could pick up the shims needed to reduce delays.
I drove my FJ a good bit yesterday and today. I may be using the wrong word to describe my issue. The steering is like there is slack or slop in there. The truck doesn’t follow groves or do anything violent. It’s just you continuously have to adjust the steering wheel. Sloppy comes to mind. Keep in mind I have all new ball joints and supposedly both the center link and pitman arm link were rebuilt. This will be confirmed w new shop bc I have my doubts. You can move the steering wheel and see the pitman arm moves almost instantly when wheel is turned, but there is a sloppy feeling when driving. Also, if you over steer or are making a hard turn it is almost as if the wheels feel like they are being pulled under the truck. Hard to describe this, but sort of like the tires might fold under kind of feeling. Camber was checked twice. Could this be related to soft bushings in the old springs? As I said, I will be doing the OME upgrade soon but am concerned that after this the truck will still have issues. I will be discussing this in detail w my mechanic but I want to have some ideas on what could be the problem. It is hard to believe “these trucks drove this poorly when new”. My past shop said that as an excuse after completion of the front end rebuild.
Play in the steering could come from any one or several or all of the steering components. All you can do is go thru them one at a time and make sure they’re good.
Have you checked the steering box?
Have you checked wheel bearings?
Ya unfortunately steering slop can come from a lot of places but with what you are describing, might be worth a look at the steering box. I sourced a manual box on ebay to replace a toyota mini truck box that was on there. Truck drove "fine" with the eBay box in terms of tracking down the road but did have that slop that you are describing. Never quite right.
I ended up taking that box to a specialty steering shop and it turned out the internals were shot and they rebuilt. Got rid of all that slop. I had previously done the TREs, rebuilt the drag link, new rag joint, and replaced the ragged stabilizer. Rebuilt box was the key.
