Steering Stabilizer
Don't waste your money on a stock one, or anything that goes in the stock holes; they just knock the center arm out of adjustment too often. Get a clamp on unit that attaches to the axle and the main tie rod. I like Rancho just because of the lifetime warranty.
I went to ARB and they did'nt have an Old Man Emu to fit in the original location, So I went to Super Cheap Auto and bought a Gabriel(made in Mexico).
The Gabriel has been fine. :)
Gabriel Dampers from Super Cheap Auto are the cheapest I've found, Yet to have any problems. :cheers:
I just love supporting Australian Manufacturers. :flipoff2: Especially ARB with it's rebadged products. :slap:
Hmmmm I have been happy with the OME SD23(40-55) or 24(60/2) I have one on......I think all my Cruisers, bolts to stock location, no problems
I had the Rancho, but had problems keeping it from rubbing on stuff when the tie rod "rolled". Maybe I didn't have it installed correctly, but it wasn't for lack of trying. I'm going back to OEM style...therefore I have a Rancho with about 4K miles on it if you want it. You can PM me if interested.
Ed
The original type with the Ball Joints in each end from Toyota was more than Australia $200 :o
I was originally quoted $76 for the Gabriel, But got it for Trade Price. - All Special orders through Super Cheap Auto are Trade Price. :)
ive got a skyjacker added on to the what looks like original stock one. seems to help some. will probably go with the ome in stock location when it gets replaced, think its only about a 20 dollar difference in ome and a napa replacement for it, so ome it is.
NAPA has nice stock stabs cheap. OME is better in the stock location. No need at all to add a stab to the tie rod unless you have big tires. Stockish tires go stock location. If you want/need a bigger stab most aftm dealers sell the same one but be careful in mounting it so it does not rub the dif or the axle
Got the OME one on the stock posts and it works a treat. But getting the old one off without damaging the steering idler was a real bastard. A REAL bastard. & mine is yellow, cause yellow ones work better than any other colour :)
sam
the key to getting the old OEM on of it to use a tie rod end seperator go to kragen and pick one up, or if your too cheep rent it for 3 days and a cost of $7.00. I think the only way to do it right is in the OE mounts. And the OME is the best if you are in the 30" and smaller size.
they came standard with 32" here so i assume an OE location one would be fine up to that at least. & I replaced mine on a island with a severe shortage of tools, only what i had with me, thats why it was so difficult.
So your Gabriel damper does fit in the stock damper holes? I've got a Stupor Cheap near me and I'll soon be in the market for a damper when I start rebuilding my front end.
If it does it sounds like a great substitute !! So what did you pay for it in the end?
[quote author=Capt Ahab link=board=1;threadid=16195;start=msg156003#msg156003 date=1084443649]
[/quote]
Same as the Instant Message I sent :cheers:
The Super Cheap Auto Receipt says:
19 June 2003
#SP100601 STEER&#039:DAMPER; GABRIEL;
1 @ 68.17
Part No. 14023
It fits in the original location, The Box included all Bushes, Nuts and Bolts.
When fitted, Go for a short drive and check its tightness afterwards. - Mine was fine after the third tighten. :cheers:
Interesting. Do you think adding a rancho style stabilizer to an existing OME one in the stock location would solve the center arm adjustment issue, or would you recommend just nothing in the stock location period?
I am no longer using ANY steering stabilizer. There has been a dynamic shift in Landcruiser ownership and use in the last 15 years since I posted.
Mall cruisers don’t need to stabilize anything. And the off road crowd has largely opted for some kind of steering assist that as a byproduct largely negates the need for a stabilizer.
