Steering stabilizer mounting bracket
Enumclaw Plateau
Hi All,
I'm rebuilding my front end and discovered that the bracket that was welded to the axle for my second steering stabilizer is broken. It snapped at the weld. Is this just bad design or should I just weld it back on like before. ( the last picture is from below and shows how the PO bolted and welded it on.) Thanks, Slow Poke
Now I'm wondering about just getting rid of the second stabilizer altogether. Do I even need one?
Nope, the only thing a second one does is mask any steering issues you may have. Ditch it and don't look back.
X2 And the reason it broke is that is a horrible weld. I would look around the cruiser for other welds that the PO might have made. Make sure nothing important is held on by similar looking welds.
Good luck! :cheers:
Come on now, really. Is this a guessing game? Look at that bugger weld with absolutely no penetration to the axle housing. Can you not see that?
Ditto on all the above plus one.
So everyone agrees a second steering stabilizer is unnecessary. Good. That makes it easy. I already pulled it off and have been cleaning up the axle for repainting. As soon as I get these parts painted up I can finally start turning my wrench the other direction.
Thanks for the input. Slow Poke
Don't assume that the 30 year old stock unit attached to the center arm is still functioning. You might want to take off one end and check it. The aftermarket stabilizer may have been added because the stock one stopped working and the PO didn't have the :balls: to get it off!
x2 on what FF LC FREAK said.
Best
Mark A.
