Here is what I would suggest (based on memory as I did this job almost 4 years ago
). Note that the clockspring is pretty fragile -it's a tiny ribbon cable. So it's hard to feel any resistance from the steering wheel before breaking it.
1. Remove the steering wheel before you start the job. I'm not sure it's possible to break the clockspring with the steering wheel removed, but you could also remove the clockspring too just to be sure.
2. When you have the new rack totally in (attached to the steering shaft and the inner tie rods in, but before you re-install the inner tie rod boots/bellows), center the rack so each inner tie rod end sticks out the same amount past the steering rack. You can use a ruler or tape measure for this.
3. Now you can re-install the wheel. But, before you do that, you'll need to re-center the clockspring (after re-installing the clockspring if you removed it). They have 5 turns total (at least on a 470). So, turn it to one side all the way with your finger, then spin it back 2.5 rotations. Then, re-install the wheel in the straight-up location. The wheel should be centered with the clockspring and the rack.
4. Re-install outer tie rod ends and set toe to the best of your ability (I did it with strings tied between two jackstands -
see here - and adjusted toe in until the tires were the same distance from the jackstands on the front and rear on both sides), and then go get a professional alignment.
