Steering Rack leak - Rubber bushes changed to aluminum
rack on the LX has been leaking for years, its more wet(DS boot) than a leak, the fluid level has not hardly gone down(I have never had to add fluid) so...untill something really goes bad.....I aint touching it :)
Christo recently told me R&R of the hundy steering rack is THE worst job on this series! None of his mechanics EVER want to do one again. That sucks for us do it ourselfers :eek:.
This Australian company make them:
http://www.fulcrumsuspensions.com.au/fulcrumCat/
Part # SPF2470K. This appears to be the mounts for up to 08/2002 models and then I guess there is a change in the design and a different mounting style?
Hey Calamaridog can I get that kit from the dealer or if I have to order it from that site where is the number so I can place and order. I haved a 98 and the driver side boot is torn in half and I have to refill my steering fluid every day. are those bushings a fix to my problem or is it just replacing my boot cover
must refill power steering ever day
leaking steering fluid
Hey calamaridog when you rack is service exactly what does it intells. and how much an i looking at. Are you sure it not just the boot that has to bereplaced cause it is torn in half
I don't know exactly. I don't consider the steering gear a user servicable item, at least not by me. If it is just a torn boot, then the part is about $15. If the steering gear needs to be rebuilt due to a leaking seal or something, I don't know how much that will cost. If the steering gear needs to be replaced, it costs about $700 for the complete assembly, plus labor of course. Potentially a very expensive problem...
You should consider getting a couple quotes. Perhaps 1 from Toyota and 1 from an independant shop.
Spresso, I don't suppose you have a picture comparing a new bushing to a worn bushing.
Thank to i4c4lo's advise and his extension tool, I was able to replaced the worn grommet with new one. Here are some photos for illustrations.
Cheers,
Anyone know if the rack is the same as the Tundra?
I helped a friend of mine install a poly kit onto his Tundra Rack about 6 months ago, said it made a world of difference.
The kit is made by Total Chaos and "LOOKS" very similar and is only $28:
Tundra Steering Rack Bushing Kit - Wheeler's Off-Road, Inc
I rather use this poly kit but like you said is it same spec or not? How about asking Toyota part dept and ask if the steering rack grommet w/ same parts number is used for Tundra and Land Crusier or not?
Good Idea!
I ordered the Tundra kit to see if it fits. If not, I will just install it on my buddies Tundra. I'll let you know soon enough:)
You, my friend, are a leader! :D
What happened to the other nylon bushing kit you ordered?
Yes Dan, your $25 OEM part may last a long time, but my imported Aussie polyurethane bushing also adds 5 HP. Besides, it's blue:flipoff2:
So where did you get the poly bushes?
I never got them. They are being held hostage by some crazy Australian types. I will have the Tundra kit this weekend and see if the main bushing is the same size. If not, I will just get the OEM bushing and call it a day.
