Steering Damper Mounting Issue?
WNY For Now
Hey Guys,
Can you all take a look at my steering damper mount? Obviously something isn’t correct here and I wanted to get your opinions before I just take a hammer to it.
Should bend the plate? Is the plate upside down? Some other issue I don’t immediately see?
Thanks!
looks like the plate has been bent, checked mine and its perfectly straight
Awesome man. Thanks. It was definitely bent like this when I put the new damper on about a year ago. I’ve been meaning to dive into it and check if it’s normal. Obviously based on how the bushing is wearing it wasn’t but…
This damage fits in with a few other “how’d that get like that” parts on the truck. Very slight tweaks here & there.
undo the bolt & slide the damper off then use a section of pipe over where the bushing goes to bend it back
I’m in the middle of Death Valley and don’t have a pipe, but I’ll dig something up and get it straight one way or the other. 😂
i don't think i would worry about it until I got home, not really critical and should work just fine for now.
Yeah it’s been like this for 10,000mi so it’s not a huge rush. But I’m full time on the road right now, so this IS home. I’ve done much bigger (stupider) projects out here.
OEM steering dampers should be an actual ball joint/taper mount. It's unfortunate more of the aftermarket doesn't follow suit. Plate may be bent, but it's always going to sit funny and be a bit wonky unless it's a ball joint end.
Put that part number into Google. That bracket looks flat in every picture
It comes flat new, but it's kind of like the Toyota OEM rust prevention. It juat needs a little time to break in and twist itself into the proper shape. 🤣 🤣 🤣
Hey Guys,
Thanks!View attachment 3200320View attachment 3200321View attachment 3200322
Might just be me, but I'd be making sure it's not being overextended. If so, could be that it's too short, or that the steering stops aren't properly adjusted. Or maybe a previous one was too short.
