On my new-to-me 94 80, the plastic shroud is loose. Not a big deal but I'd like to tighten it up. What holds it in place? There are a couple of holes in the bottom of it. Should there be screws or bolts in those holes. If so, anyone know what size? Since its loose, it rides on the backside of the steering wheel and sometimes squeaks.
Unfortunately, SOR has #80 listed as discontinued and not available, they may know the size though (Not much help, sorry...composed this whole post before I realized they didn't have the #80 in stock, maybe you only need the #81's)
Careful buying the used parts. I bought replacements and it was no better than what I had. When it arrived and I seen it was cracked I called and they said they did not know I wanted a good one and it was more money. I will never buy from them again.
There are three screws that hold the lower shell to the steering wheel. Check to make sure they are tight. Also, there are 2 screws that hold the upper and lower halfs together. If all are tight and the cover is still loose then the mounts / threads on the inside of the cover are stripped and or cracked. The plastic gets brittle over time. Had the same issue with mine. You can attempt the various repairs to glue the plastic together like I did. Most won't last very long. I finally was sick of repairing the covers and just ordered a new upper and lower cover.
As far as size/type of screw, check with toyota to get the right ones or somebody else can chime in.
Pete
Thanks for the replies. It looks like it is the three screws that are missing. The two halves are screwed together and it seems to be in pretty good shape, just moving around. If I take apart the two halves I guess I should be able to figure out what kind of screws/bolts to use.
Experiences vary, and SOR is expensive at times...I have spent thousands of dollars there and never been dissatisfied. This may be different once I start buying for an 80 instead of getting fj55 or fj60 parts...
a boneyard may be able to provide the whole kit and kaboodle
The plastic that my bolts screwed into is busted as well, The new cover is a pricey piece, in a pinch I am using 3 black zip ties as a rubber band to squeeze the upper and lower pieces together, it works well for the time being and has eliminated the squeak.
The plastic is way too brittle. They should have used a slightly softer plastic. It's not really made for taking apart. Most likely it's broken. You will probably have to find a good used one or have to get a new one.
Once you do this, reinforce the entire inside of the assy with a coat of epoxy. Include the towers where the screw holes are but don't let any epoxy get in the screw holes.
Let everything dry and test fit the two halves together. If they do not fit properly you can dremel some of the epoxy away.
Make sure you have the proper screws and carefully put everything back on your truck and pray to the land cruiser gods you don't have to ever remove it again.
I did replace my covers with used ones from SOR. The parts they delivered were in good condition and I assembled them with great success. No issues. Day 5 after the installation I banged a knee on the column and busted it again, doh. Appears that the plastic is a bit too brittle for something that will be regularly tapped by us long-legged folk. I now let it float around.
Mine broke when I attempted to enter the truck after a much shorter person had adjusted the seat all the way forward. Nailed it with my knee. I removed it and superglued (the ends of the sockets where it screws to the column) then reinforced it with epoxy. Going on two months and the repair is still working.
I have had good experience using JB weld on other vehicles fixing similar panels with cracks, broken mounting posts, etc. You can drill, sand, grind to shape and replace the broken bits, and it will hold up better than stock. Luckily mine is still in good shape.
