Steering arm close call
It is a common problem with lift and big tires, 80 and 105s are prone to have this problem. It requires inspection once and in the while. I do it every time after off-roading.
I had two of the four studs (nuts and cone washers attached) fall out on the passenger side when the Cruiser had about 125,000 miles on it. When I bought replacement hardware from Cdan for the two that fell out, he told me someone had all four studs fall out and the steering arm came out of the knuckle causing the left front wheel to tow in causing a major accident. When I rebuilt the knuckles (back in NOV 15) I replaced all eight studs, cone washers and nuts, and red Locktited the studs. I torqued the nuts dry.
I know it is a pain but they should be checked anytime you are heading out on a longer excursion. I check mine every 6 months at the least and then anytime I am heading out to the back country. I had mine loosen up several years ago, replaced with new studs and did the tapping trick while tightening. Did not use loctite. Since that time, about 3 years ago, I have had one nut that was "loose", it only needed a few foot lbs to snug it up.
The bottom line is that we should always do a once over on these things before a long trip, and I don't just mean checking the oil...
I've seen this happen to (3) 80's, in person. One being myself. All were passenger side. All happened on the trail. Check your nuts.
I had this happen to me with the studs. When I bought my truck, I knew one stud was sheared off because the PO had hit a guardrail at some time in the past. Also, the wheel bearings were slightly loose.
I discovered that two more of the studs had fallen out and the last stud was working its way out and was not even close to finger tight. My truck needed a front axle rebuild anyway, so I went in, cleaned out the knuckle balls with brake cleaner to make sure they were oil-free. I then put red Loctite on NEW studs and torqued them to 40 Lb-Ft. The manual does NOT list a torque for the STUDS into the knuckle ball. I had to use the double-nut method to torque them because the Torx end sheared off at less than 15 Lb-Ft.
I then assembled everything after leaving it 24 hours to cure with no oils present. Once assembled, I installed the nuts with BLUE loctite, making sure to keep the cones dry, I used a hammer to tap the steering arm over and over from multiple angles in order to make sure it was well seated. My final nut torque was 70 Lb-Ft per the book spec.
Prior to this, my truck has never had any off-roading, just VERY poor maintenance by the PO. It also had the standard 31" Michelin street tires and the problem occurred on the passenger side.
I now have 33" tires and only plan to do moderate wheeling, but it is my DD. I am VERY aware off the symptoms of loose steering arms now and I do a visual on it regularly. If one retorques the nuts after having put on Loctite, the Loctite is no longer effective after it had cured then been turned.
If the steering arm falls off the passenger side while driving down the road, you will lose ALL steering because the right side controls the left side and if the right falls off, the left cannot do anything. The wheels will go EITHER toe-in or toe-out. Either way, it's a losing situation.
Glad I'm not the only one who believes Loctite is acceptable, as well as a good idea, to use.
ARP studs, loctite, torque, re-torque often
ARP recommends loctiting studs into knuckle
Plenty of tech on this out there in the mini truck world. Nearly the same setup.
OP here. I was going to do this repair and knuckle rebuild myself but I'm pretty anal and it would take me at a couple weekends to get it done and probably not be ready for the Tierra del Sol run.
So I spoke with the guys at Yotamasters in Corona, they are a well known shop with great reputation for mini trucks and land cruisers, and will have them do the job. They will use heavier duty studs to make it stronger and then I will make sure to check them after every trip.
He mentioned there where two levels of stronger than factory studs available. I will get more details when I drop it off next week.
The newer factory studs are really good upgraded material. You can use the ARPs if you like, or the mystery metal ones from trail gear, but the factory studs are tested to apply the correct clamping force when torqued to spec. The factory even upgraded this part after the trucks left the factory, so they likely saw it was a weak spot and did a really good job of the replacement. The torx head makes it easy to turn into the knuckle and seat firmly. I don't think there's a torque spec for that so be careful and don't pull out the soft threads of the knuckle.
For the record, I'm a loctite into the knuckle believer, and don't use locktite on the nuts.
Offroad, we have everyone in the group check these studs at the beginning of every wheeling day. Cheap insurance. I have seen way too many of these loosen up on other trucks, even trucks with known good maintenance.
One other data point-I have the TG 6 stud knuckles on my FJ60. It has high steer, 37 inch tires. I've never had one nut loosen even a crack on that truck and they have been in place since 2008. I wish there was a way to upgrade the 80 knuckle to 6 studs since I feel it distributes the steering forces better and does not promote loosening in the same way.
