Steering Arm and alignment
Boston
Hey all, I'm trying to get my steering aligned and the shop is telling me that the tie rod sleeve is at maximum adjustment yet the wheels are still toed out. I have measured the tie rod sleeve at 42 3/8" length and this has been confirmed by Kurt at Cruiser Outfitters.
Upon inspection, I think I have a bent steering arm. On the passenger side I can fit my finger between the arm and the rim, on the driver side I can't. (see pics).
Can anyone tell from the pics, and should the steering arm be the same as the drivers side (i.e. close to the wheel). I'm thinking this is what is causing the toe out.
My truck is a 1977, and I know the PO has done lots of strange mods that I'm having to rewind. Could these be arms off a later 1979 FJ40? Do they have the same bolt pattern?
Help appreciated
Phil.
It does appear that arms are different, that could be problem. Also tierods are not screwed into tube equally, that mite help. I'll give $25 for rig if you can't fix it.
is this that modified rig from a few months ago?
assuming power steering? Saginaw?
lots of threads showing on that one end, drag link?
the 79 arms at least the ones i have are the large bolt pattern with the smaller tie rod holes .i use them when i go to dick brakes makes it a bolt on job
Did you try disconnecting all the ends and bottoming them out in the tie rod? If not then disconnect the drag link end from the passenger side then disconnect the passenger side end link. Screw it in until it bottoms, you'll have to loosen the clamps. Once you have it bottomed then simple turn the whole rod to bottom the drivers side link and then reconnect all the end links and check your toe in again.
