I like R12 and don't think it can be beat, that is of course if you want to pay $$ for it nowdays. I'm of the view that automotive a/c systems just run better with R12 (those that were made for it).
Again, I can only speak of what I did, but that was based on what many people told me when you convert to R134a. Clean out the entire system since the new PAG oil is not compatible with the old oil. I used cleaner that is designed for this. Replace all O-rings in the entire system. Replace the dryer. Replace the seals on your compressor. Replace the expansion valve. This is a pain, but not only most likely needed, it also gives you the chance to clean off the evaporator, which is most likely very dirty. Then add the PAG oil and put a vacuum on the system to check for leaks. If that checks out, charge the system. Good luck.
Oh thanks for the info. Can you tell me where to find the Toyota Technical Service buletin ?Just turn the compressor over and let all of the mineral oil drain out. The Toyota Technical Service Bulletin on the R134 retrofit even says you don't have to drain or flush the mineral oil.
PM sent.Oh thanks for the info. Can you tell me where to find the Toyota Technical Service buletin ?
@4Cruisers any reason not to put it up on this thread for public?Oh thanks for the info. Can you tell me where to find the Toyota Technical Service buletin ?
Got this from another forum somewhere.
BTW thanks for the post, much appreciated.Got this from another forum somewhere.
