[quote author=Imagery link=board=2;threadid=4967;start=msg40101#msg40101 date=1063249263]
This is what my buddy was probably refering to initially..The knocking in the engine after changing oil types. Would it hurt anything to try the M1 0W 40, and if it begins to knock when starting up, then just try another like what Cruiser Dan uses, or even just go back to the 10W 30 or 10W 40??? Also, I had been going to the same place to have my oil changed and I would just supply them with a Toyota filter (not sure what model, but whatever Toyota reccomends), and he told me that there is a "high pressure" filter by Ford that works good with my Cruiser since it is a higher compression engine than ordinary. He showed me the size difference and the Ford filter had a buldge on the bottom rather than a concave such as the Toyota filter. Perhaps I had a smaller size Toyota filter, but it is what the dealer parts department gave to me. When I go back to get my filters, which one should I more specifically ask for? I am just going to start doing my own oil changes at home because I am alot more attentive to what I am doing and I don't over fill/spill oil all over my motor and axle.
[/quote]
Not to be a dick, but your buddy doesn't have a clue what he is talking about. The compression ratio of an engine has nothing to do with the oil filter, oil pressure, or oil weight used. See my other post about changing oil weights, it is not a problem. You buddy sounds dangrous, as in just enough knowledge to screw everything up.
Cary
[/quote]
Cary
