I have a 1996 land cruiser that starts fine when its cold. If you drive it and it warms up and you shut it off it wont restart. If you turn the key to start it will dim all the lights and yet no click or crank. I had the starter rebuilt...didnt fix it...Bought new battery cables...didnt fix it...im stumped. It will start over and over when its cold....but you drive it around for a while...shut it off...it wont click or crank. If you let it sit for a long time it will start right up. please help
Try jiggling the key in and out with the key in the Run position, i.e. work it around, in and out, but avoiding going to start. After a little of that, then turn to Start. If it starts, most likely it's the switch behind the key cylinder. The contacts get ugly and the jiggling helps move things just enough to make proper contact. The switch was around $70 IIRC. This is the problem I have currently and the jiggling usually does the trick.
The wiring down to the solenoid can also be related to your problem. Several threads here on that, might try a search term like "bypass starter solenoid wiring" or something similar to find them.
i have tried messing with the key and so far have had no luck. when its warm its like the battery is weak....you turn the key...no click...co crank...the clock dims and the lights dim but nothing happens. It starts right up when cold...over and over...but if its good and warm...you shut it off...your done...lights are still bright and accessories work...but it wont crank or click
i had a friend check the battery and the alternator and everything is working perfectly. But its still not starting when hot. Its starting fine when cold but a short drive of 15 min and you shut it off and it wont start...the lights dim but no crank
Sounds like battery to me. After it sits and cools, it "recharges" just enough. After it's warm, it has "heat soak" and it won't put out what is needed. Check the voltage across the terminals with the truck off. Should be between 12.6 and 13.6 VDC. If 12.6 or below, it's on it's way out the door. If it appears OK there, pull it and have it load tested at O'Reilly's or wherever. The load test should tell the tale. They'll do it for free. If no luck there, then back to the starting circuit.
Fusible Links on the battery? They can go out or be temperamental. Just get a new one (or two) from CDan (about $15 each) Good to have on hand in the truck.
Do yourself a favor and install a jumper wire on the remote lead of the starter solenoid.
Next time it happens, check voltage at the jumper while cranking.
If it's low or 0v, then you'll know the problem lies between the ignition switch and the starter motor (which may also be the NSS)
Best of all, if this is the case, you can rule out the start motor as the culprit and use the jumper wire to trigger the solenoid by simply touching it to the battery
I've had similar problems before, even with a brand new Mr-T starter motor
Turns out my ignition switch would randomly not send enough juice (or none at all) while starting , so I bypassed it with my own relay/hidden switch and adjustable timer with push button
I was thinking jumper wire like he said^^ als0. Another check to possibly do is After the truck is warmed up and running - when you go to park, shift the transfer into neutral and make sure the red A/T light is on the dash lights up...to see if your neutral switch is not sticking???,
