Starting problem '77 2F.
TCEd
Traverse City, MI
1977 2F stock engine assy.
Cranks but will not start, recent problem but previously it usually took a lot of gas pedal pumping and choke to get it started.
Give it a shot of Ether and it fires and runs/drive fine.
Once driven and turned off may or may not restart without ether.
Carb sight window half full of fuel.
New spark plug didn't help.
The fuel pump appears to be a recent replacement by P.O.
Air filter removed makes no difference.
Any Suggestions ?
ed
Thoughts...
Is the fuel filter clean?
Do you have crap in your tank? When the fuel settles, after you shut the engine down, something could be blocking the pickup.
Are your hard fuel lines clean? They are a low point... they accumulate water and sludge.
Are your soft fuel lines cracked? Are any of your clamps bad? Could be sucking air, along with fuel.
So, fuel pump is mechanical? Is it actually pumping enough fuel @Pin_Head suggests:
“Disconnect the fuel line at the carb and see if it can pump 1 cup of gas in 15 sconds of cranking (witht he ignition wire disconnected).“​
The PO didn’t install the replacement mechanical pump, using a spacer? I don’t believe a ‘77 uses a spacer.
Is there a (dirty) screen, inside the fuel inlet, on the carb?
Is the choke working properly?
U mention a New fuel pump , what's the condition of the fuel filter ?
is it New or Old ......
a simple clogged fuel filter would cause the symptoms u describe
if old , i would simply replace it with a OEM toyota part u can still get at your local dealer
Check to see if your accelerator pump is squirting down the carb.
had trouble with mine and the ballist resistor was the problem check fuel delivery first same symptoms
Gas in carb bowl? Check.
Spark at plugs? Check
Idles OK once running? Check.
Won't start unless primed with external fuel?
The Accel pump was dying, now it's dead.
Rebuild carb, being sure to clean out AP discharge nozzle.
Thanks for the reply and suggestion to rebuild carb..
Everything leads to what FJ40jim suggests. Now my second problem. This is a '77 FJ40 but was told the engine is from a 1982 FJ40. Any suggestion on how to determine what carb. I have ? Guessing they have different part numbers if they're different. ed
Thanks again FJ40jim, mine says 2 B 10 which matches up with it being a '82.
Ordered the Standard 791B rebuild kit on Amazon,will get it Thursday. Watched the Pinhead videos and I'll post back once I figure out if my eyeglasses are adequate for doing this project ! Thanks for all the help in finding a direction to follow. ed
Points? When’s the last time you checked the dwell? I just had this discussion with @Rigger. Don’t know how many times a carb has been fingered as the culprit when it’s really the victim.
No points, '82 distributor, '82 engine.
Check to see if you have the original '77 dizzy or the '82 dizzy from the '82 2F swap.
Just a little help for the carb rebuild: Rebuilding an Aisan Carb - Part 1
Yes thanks, I watched all of the disassembly and cleaning chapters last night. Plan to view the assembly stuff tomorrow. It has the '82 distributor, big cap and dent in engine side cover.
Well this took a different turn. To prepare to remove the carb I sprayed everything that moves, the interior/exterior orifice with carb cleaner followed by WD40. Later magically it starts and starts again and again and has continued to start for the past three days. So for now i'm going to put the rebuild kit on the workbench and use the vehicle. ed
