Starting Issues...ugh
Hi there, I've got a 1996 Landcruiser with 185k miles, that I've owned since about 150k miles. Over the past 8 or so months I've had some pretty frustrating starting issues...they started off being intermittent, but now they're permanent. I've read on this forum for hours upon hours, and done many of the things recommended, with no luck.
I originally thought it was the starter, so I replaced that (it was looking pretty ugly anyway), that didn't fix it. Battery's good. Then i added in a relay between the ignition and the battery (I had done that on my old '85 Toyota and fixed the issue), that seemed to fix it for a month or two. When it started having starting issues again it got to the point where I can turn the ignition as many times as I want and it won't start up. So, I wired a push button to start the thing, that works every time without fail (that rules out the battery and starter as far as I can tell).
Although it consistently starts up, I'm not a fan of the push button so I'd really to get it fixed. I've checked the wiring harness on the neutral safety switch, and that seems to be ok. When I put the test light on the wires going into (from the ignition) the harness, I don't get any readings on power to it...which makes me think the problem has to be either the ignition, or somewhere between the ignition and the neutral safety switch.
Any thoughts on where I should go from here? I don't even know how to start troubleshooting the ignition as I've never touched it before and don't really know all that's involved. One little tidbit of info that may or may not play a part in this is typically when I take the key out of the ignition in turns off the headlights, lately if I pull the keys out too fast, it doesn't turn the headlights off....so I'm wondering if that could be somehow related. Any help would be much appreciated...
Have you replaced the ignition lock cylinder? Remove it and clean with lectromotive contact cleaner by spraying and working it a few dozen cycles and see if that helps. That is assuming removing the ignition cylinder is visually in good shape.
Hi there, that was the last thing I did, I took out the ignition lock cylinder and examined it, it seemed to be working to me and wasn't corroded or anything so I just put it back in, I may have put some wd40 or something on it, can't remember for sure.
You could check with a multimeter and make sure the starter solenoid is getting 12 v when in the start position. the button works so its either wiring from the switch or the switch, depending on how you wired up the push button....between those two points at least. I'd replace the cylinder based on your description but to be frugal test it first.
Given the tidbit you mention....I'd still go after the switch. You could unplug it and jump power to starter hot and see if the starter engages. Which is basically what you have done with the push button....
When I turn the ignition no power gets to the solenoid of the starter...it doesn't even make it to the neutral safety switch (as far as I can tell).
What switch are you referring to? A switch in the ignition?
Yeah, the ignition switch itself. Something is going on inside that thing and I bet there is a contact that is worn or corroded.
Have you checked for continuity from Pin 1 of the ig. switch to Pin 6 of the neutral safety switch?
Next check continuity of Pin 5 from neutral safety switch to starter relay.
Does it have an alarm system? (factory or otherwise?)
It may have a defective ignition kill relay.
Slickspawn, thanks for the advice, I haven't checked at the pins, I'll need to look into how to do that.
Lndcrshr, it does have the factory RS3000 alarm system, any idea where I would check the ignition kill relay from that?
Just removed my system last weekend, sorry I didn't take pics.
The relay was in behind the left kick panel, tucked behind the bracket for the ABS ECU. It was wraped in adhesive foam.
There is a good thread here somewhere on removing the factory alarm.
The key part is removing it from where it taps into the ignition harness.
The connector you're after is below the steering column, to the right, just on top of the A/C duct.
You'll have to remove the lower panel and the metal reinforcement panel too. It also helps to remove the duct for easier access.
The alarm harness "tee"s into the Ignition harness with connectors. Just remove the alarm side of things and plug the remaining 2 connectors back together.
Sorry for the long-winded response, hope this helps.
Hmm, I wonder if just removing that t connector that goes into the harness could be a good way to troubleshoot whether or not it's the alarm causing the issues, thoughts?
That's what I'd do, because the problem could be in the alarm brain too.
Would only take about 10~15 miniutes.
Well, just tried removing the alarm t connector, pretty easy to do, and i was able to connect the harness together without the alarm t connector, but that didn't fix the problem. Unless I'm missing something, that means the alarm is fine and it's down to ignition or wires coming in or out of it...now to start testing voltage I guess.
After a couple more hours of troubleshooting with the voltmeter I've determined that the ignition is good. I checked the wire from the battery before the ignition and it had power to it, I checked the wire after the ignition (while turning ignition) and it had power to it as well.
So, I guess that leaves me with somewhere between the ignition and the Neutral Safety Switch, or the Neutral Safety Switch itself (I've attempted checking that twice including taking the harness apart). At least I'm getting somewhere. I have a strong feeling I'll be changing out a neutral safety switch sometime soon...
Does anybody know if there's anywhere else I should check between the ignition and the neutral safety switch?
It's been some time since I tried working on this, having a push button kind of takes away the urgency. I just tried taking off the neutral safety switch connector (for the 3rd time), and rechecking the black/white and black/red wires that come from the ignition and head to the starter and they were fine, no corrosion, nothing. I tried jumping them together and still no start with the turn of the key. So now it seems like it HAS to be somewhere between the ignition and the NSS.
Any help would be appreciated. Is there somewhere between those two points that is most likely to fail?
