Starting Issue!
Venice
I have an intermittent problem. Once in a while I turn the key and nothing happens. The lights on the dash come on but there's nothing happeninng. Like the starter is not getting contact. I try again and it will turn right over. Is my starter motor going out or is it a loose contact or something? I read the FAQ on starting and it seems like if it was a fuseable link or something it wouldn't start period. I'm thinking it's the starter motor. Any advice?
Search on this one...
I had the problem and fixed it but nobody else had my problem. Lots of advice and trouble shooting available on a few recent threads.
Sounds like classic worn / corroded solenoid contacts. When it doesn't go, does it click? Pull the starter, take the end off the solenoid and replace the contacts and plunger (you may be able to just clean up the plunger).
I just finished reading through this thread https://forum.ih8mud.com/80-series-tech/172212-intermittant-starter.html. Great information!!! Read roncruiser's post (#24) and link from there. It sounds like it could be quite a few things, but at least a nice checklist of things to check is well underway.
Thanks again for all that contributed to that thread as I had one occurance of "no start, no sound" a while ago and will be saving that thread for future reference!
Riley
Thanks. I went ahead and ordered a new starter. A weak solenoid is the culprit i believe. I'll report back after the new unit goes in tomorrow. It only happened occassionally, but if i go a few days with no issues i'll have faith the problem is solved.
Leroy,
It helps everyone if you will post details of your rig in your sig line or in your post. For example, you could have a 24v diseasel system and it is possible for it to have a completely different set of problems than the more common 12v petrol engines that we have in North America. We cannot tell where you are from or what vehicle you are having problems with.
On a sidenote... if you have a '93 (US specification) check to see which starter it has. There are a few '93s with a HD starter (2.4kw IIRC) and it would be in your best interest to NOT use that on exchange for the new starter that you ordered. Those starters are highly sought after and easy to rebuild.
We also have a comprehensive FAQ section her in the 80-Series section. It has a good bit of information on the starter R&R and the starter "rebuild" (basically just replacing contacts and plunger) and a trouble-shooting discussion.
-B-
Unfortunately, intermittant starts are my specialty :lol:
Unfortuantely, solving intermittant start problems are my specialty :)
Nice!!! Thanks for the follow-up. You just cut to chase, purchased a new starter and got lucky that was the problem.
:cheers: To you!
Riley
You mean your "no start when hot out" issue? How did you resolve it?
Go up a few post and check the thread Driley linked, it has pics of my problem. It was a broken wire in the NSS harness.
Well.... i'm having a starting issue AGAIN!
i replaced the strater motor 6 months ago and haven't had any issues... unitil I was drinving back from Yosemite on Monday and stopped to eat. Went to start the truck and nothing happened. No clicking and no turning over. BAsically scenario 1 in the troubleshooting of the FAQ. I checked the fuses and all looked good. I checked the fusible links (i knew how to find) and they looked good. Checked the battery cables... all good. I resigned to calling AAA and then i pulled the drivers side kick panel and starting plugging and unplugging and few things and then tried to start it and it STARTED! WTF!.... so i jumped in and drove home without shuitting it off once. Now it's dead on the street and won't start, but at least i made it home. When i press the brake pedal i can hear the neutral safety switch click so i don't think that's it.
So... i have anotheer starter on the way under warranty.
But.... a couple questions:
1. Where are the starter contacts exactly?
2. When i turn on the key i get a red light at the voltmeter on the dash. not a yellow light. does this mean my AM2 fusible link is bad? if so where is it exactly?
some help is greatly appreciated. i can always put in the starter even though it's a PITA, but if it strats consistently after that i guess i can assume the replacement starter was just bad. or, am i missing something here and it could be something more?
The contacts are inside the solenoid portion of the starter. Pics in the FAQ, on Christo's web site, and on George's web site.
Did you by a reman starter from Toyota?
How is the battery?
Check the connections at the battery and at the starter. I know you said you checked them, but check them again. The battery ground to the block and to the body is very important so check them a 3rd time.
-B-
You need to tap into the wire going to the starter solenoid from the ignition and read your voltage when trying to start it. If you get 10-12 volts when trying to start then your wiring is good and I would look at the starter. I you don't even get a volt (like my problem) then you are looking at a wiring issue (broken wire, corroded connector, etc.) This will point you in the right direction without just replacing parts like most people do.
I bought a reman through pep boys. should have gone toyota....
the battery is good. it started right up when, for whatever reason, power got to the starter motor.
i'll check the grounds to the block and the body again.
when you say the wire to to starter from the ignition... do you mean the wire with the plastic connector on it?
I second this, big time! I had the same symptoms as you (Leroy) and replaced contacts, tore the dash apart to check the ignition switch, and a bunch of other stuff. It would have been a lot easier if I had followed TOY350's advice right off the start. Check your NSS connector at the transmission for corrosion and/or broken terminals (one of mine was broken in half, one was nearly there, and they were both somewhat corroded). It will either lead you directly to the problem, or rule out a major component of the problem (wiring).
:cheers:
i've got a voltmeter on loan so i'll definitely test the wire that leads to the solenoid. in this case i hope i get the volts i'm looking..... i'm an electrical retard but i think i know what to do here. if the volts check out then it's a matter of changing the starter which is something i think i can handle. i hope it's just the starter and not a wiring issue.
thanks for the excellent tip TOY350.
i'll post up my findings.
I'm not much of an electrical guy either (although troubleshooting this problem helped fix that :rolleyes:) so I'll just point out that the truck has to be "having the no start problem" when you try this test. Then you have to get the probe of the voltmeter into the backside of the solenoid trigger wire connector while it is plugged into the starter, ground the other probe, and get someone to turn the key. HTH!
