Are you sure it's the starter? Sure, starter contacts are a common source of trouble, but not the only one.
Do you get any relay clicks from down by the driver's kick panel? Or does it just do nothing?
A somewhat less common fault is the ignition switch. Not the keyed part, but the electrical stuff behind the key's lock cylinder. Just fixed a large part of my intermittent no starts yesterday with that and added some more pics to the most recent thread:
https://forum.ih8mud.com/threads/ignition-switch-replacement-procedure.841286/
One way to determine ignition switch involvement is to put the key in the ignition. Instead of turning to Start, turn to the other positions BEFORE Start and jiggle the key in and out on each one several times. This will eventually move the contact plates enough to get good contact and crank. So jiggle first, then turn to Start, repeat until it cranks.
If that doesn't work, then probably not the ignition switch. Mine has come and gone for about a year, on and off. I suspect starter contacts will be part of the issue eventually, which is not surprising on a nearly 20 year old truck. But my case was clearly one where it might have been the starter contacts a time or two, but most was the ignition switch.
Here's a pic of the new/left and old/right ignition switch contacts. I wiped the worst of what was covering the old one's contacts off in order to see the metal underneath. Note also this is the disassembled switch. See my instructions in the linked thread otherwise you'll have springs and the two balls flying every if you disassemble the old switch. You may want to have a new one available. Even if you just pitch it, I'm keeping mine for a spare after I clean it up
