- Do the dash lights dim as you try to start (does not turn engine over). This can indicate either bad starter or weak voltage to it.
- Does the security light go off as key inserted and stays off with key in IG.
- Did you check battery voltage with multimeter both from battery posts and from positive clamp and a ground (not touching tester to post). You should have better than 12.7v and the same from all test points. If not, the issue is like oxidation on clamp & post or loose clamps or both.
- Are battery post clean, greased ( I use white lithium grease after clean post and clamps, to retard oxidation) and clamps sung (do not over tighten)
- Any chance you even touch the gear shifter, and then it started. Next time it does not start, try shifting to N and then see if starts. Also try slamming back to P from N and try starting again. If you can repeat this consistently, likely neutral swatch issue.
In non VVT engine. It possible to see starter through intake manifold. If all above checks-out as it should. Next "no start". Use a steel rod (should be one in tool kit (chrome hub cap remover)). Tap on starter (care must be taken too tap on metal of starter, not plastic) with steel rod. This can vibrate starter contact washers. By vibrating (which repeatedly turning on key can do also), the contact washer(s) may move a little. They then often, hit a good spot on contact and starts. This is a sure sign contact need replacing.
Tip:
Reset contact of all rebuilt starters, before install. All to often, rebuilders do not properly set contacts.
I think I have a bad Neutral Switch then.
1. The lights do dim a bit when I turn the key to the start position. But the main battery holds 12.5 volts overnight, sitting on 12.8 after a charge or drive. Load tested as good. Voltage from battery terminal to engine block is the same as across the terminals, 12.8 volts. I have a dual battery system installed, and when the problem occurs using jump leads between the two batteries doesn't help. The starter spins the engine just fine when the problem doesn't occur. Charging overnight does sometimes help, but not always. Lately, not really at all.
2. Security light goes off with key in ignition. So not the immobiliser. Besides, engine doesn't turn over. (Tries. More on that below.)
3. As above, voltage good enough.
4. Good clean connection. Engine earth seems good.
5. This. When the problem happens I have been able to get the engine to turn over, and it starts, when jamming the gear shift hard into Park, or just moving it back and forth a few times. Engine won't turn over in either Park or Neutral... until it does. I found that pressing the lock button on the gear shift helped a few times, but not so much now.
The differences in my situation:
A. The starter solenoid clicks just fine, and I can hear the starter gear engaging. The starter motor seems to try to turn over the engine, and sometimes will just a very little bit, but doesn't continue... until it does. This would indicate weak power at the starter. I guess there could be a bad earth at the starter, if it isn't via the engine block.
B. After warming the engine restarts seem to work fine. I commute half an hour morning and night, and usually I can start the car after 9 hours at work. Getting harder though.
C. Leaving the key turned on for a while seems to help a little. I can hear all the start up noises such as fuel and power steering pump, but still hear a slight whine that continues after that.
Note that the gear position lights in the dash all show the correct gear position. So the car knows what gear it is in, and won't try to start in R, D, 2, or 1.
Also, the charging voltage from the alternator is 14.25 volts, battery terminal to engine block. Same across battery terminals.
So, while I think my battery (2 years old) may be a little weak, something isn't getting enough power, or maybe something is stealing power from the starter for some time, and only when that process finishes the starter gets enough power to crank the engine.
But the "wiggle the gear shift and it works" thing certainly points to the Neutral Switch. Would the starter solenoid engage if the Neutral Switch was bad, or on the way out?
Comments?
