Starter Connections
Lafayette, Colorado
To get my newly rebuilt 2F going in my '72 FJ40 I need to make the connections to the starter and I don't think the previous owner had things connected correctly. Does anyone have pictures of their starter connections on a '72? From the FSM it shows:
"30" Terminal going to the + side of the battery. No question here.
"50" Terminal going to the ignition switch. Is that the black with white stripe wire coming out of the firewall?
What about the wire coming off the solenoid with female snap terminal? The FSM says To Ignition Coil (Only for USA). :confused:
"C" Terminal connects the starter and solenoid. No question here.
Sorry I don't have a picture of the illustration in the FSM for reference.
Thanks.
That all sounds right to me (but I'm not an expert on the wire colors, so I'd test that one).
The wire to the coil is a ballast resistor bypass. Normally with the engine running, your coil is powered through the ballast resistor, running on 7-8 volts or so IIRC.
But, during starting, when the starter solenoid is getting power, the bypass wire allows a full 12 volts to the coil for hotter spark during startup. As soon as you let off the key, the power is cut to the solenoid (and, thus, the bypass) and the coil runs on 8 volts again.
Kent, I think Chris Hatfield (Sharkbait on Rising Sun and Hatfieldcb (sp?) on here) just went through this in earlier this year on his 40. You might want to hit him up via pm for his input.
Follow up.
Jeff Zepp let me take a look at his FJ45 at the Rising Sun 4x4 Rally yesterday so here is what I found out:
"50" Terminal going to the ignition switch. Is that the black with white stripe wire coming out of the firewall. Correct.
The wire coming off the solenoid with female snap terminal isn't needed on my '72 FJ40.
I think I'm good to go. Now I just need a new Gas Tank and I'll have the Cuiser back on the road. :steer:
Are you using the original starter or the newer gear reduction starter? The original starter requires the ballast resistor bypass. The newer GR starter only needs the black with white stripe wire from the ignition switch and the cable from the battery. When the original starter on my '78 went out I went to the GR starter out of a FJ60. It only has two connections; ignition switch to solenoid and the battery. I taped up the ballast resistor wire and left it there.
The ballast resistor wire is there to bypass the ballast resistor on the ignition coil during starting - it has no function for the starter, but should be there for easier starting, as it supplies a full 12V to the ignition coil during starting, this voltage then drops thru the ballast resistor once the starter is disengaged
Do I have a ballast resistor on an FJ60 coil pack? I'll take a photo of what I'm working with and post it tomorrow. Thanks.
